Thread: Heater Blower Motor suddenly stopped
    Jun 2009
    Brighton
    Question Heater Blower Motor suddenly stopped
    Hi there, I have a 1.9 CDti 150 estate which all in all is fine for its age (55 plate; 110,000 miles)
    I just noticed today that the heater motor is not running. I checked the obvious; fuse is OK and I measure 12 V on one side of the fuse holder when fuse out. It does not work on any speed and the de-mister button also does not work; usualy sends fan into some high speed mode.
    Any quick diagnostic tips, experiences would be most welcomed. Its ****** typical such a thing would fail when it is -2 C outside now. Lol.....
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 133000
    does it work on number 4 ?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    PMed you
    West
    scuttle drain blocked?? if so it's likely that water has killed the resistor pack, not really a big job... heater blower & resistor is all behind the glove box
    Jun 2009
    Brighton
    Hey chaps all sorted for now and only cost me a pollen filter. When I looked at that scuttle tray part, drain was blocked and a good half pint of water; and that was after being stood for some hours. Unblocked drain, cleaned tray and replaced filter. I reached in and turned blower motor; slight resistance but then OK. On trying blower again all worked fine on all speeds. I tried to lube the top bearing insitu but not really easy to do. The motor seems to have a very slight resistance but im not sure what is normal. It runs fine now so I presume the resistance is not a problem. One thing I cant quite uderstand is that the blower was obviously temporarily siezed by crap of some sort yet it did not blwo that 15 A fuse?? Maybe its the wrong value??
  1. help heater blower motor
    By whitevanman in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2010, 01:27
  2. heater motor has stopped.
    By Jen in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2010, 20:23
  3. Heater blower stopped working
    By owb82 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2009, 18:24
  4. Heater blower has stopped working
    By Dave1971 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2008, 12:55
