Thread: PLEASE HELP!! Error codes p1105 & p0105
    Jun 2012
    essex
    Default PLEASE HELP!! Error codes p1105 & p0105
    Got the error codes p1105 & p0105 but yet I have replaced the map sensor and no joy please help the car won't boost
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    What car?
    Checked all turbo pipe work? Checked turbo actuator moves freely?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    you had this problem back in July...
    Jun 2012
    essex
    Signum 2.0 dti.... and okay I will try that in the morning. Because I have read othrt thread and they say bout the MAF & MAP SONSOR with I Havre now replaced both at the same time thinking it would solve it and nothing and
    Yer I had the same type of problem but it was due to the EGR VALVE being clogged up with ****
    This car has being nothing but a headache mechanically
    Thank you for you help guys
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Quote Originally Posted by signum_05 View Post
    http://www.vectra-c.com/forum/showth...0105-and-P1105
    Regular Member Innes's Avatar
    Plymouth
    I had these codes and it was the barometric pressure sensor. £40 from dealers.
    http://www.vectra-c.com/forum/showth...ble&highlight=
    edit: just noticed someone else posted my bread further up :-)
    dirtydan
    Guest
    Has anyone had any joy? I think I'm having similar problems. Not sure of the codes (I'll get them read again soon) but I've had MAF sensor and EGR faults, massive loss of power and stuck in limp home mode. Changed the vacuum sensor / boost pressure sensor after taking it to a local mechanic, then changed the intercooler (apparently it had split) also had the EGR taken off and cleaned thoroughly but still no joy. Car is worse than ever. At first I'd just turn it on and off a few times to get it out of LHM but its on all the time now. Won't go over about 2000rpm and really struggles to get up any kind of incline. Please help! I'm in Nuneaton, Warwickshire if anyone knows of anywhere local to go? I can't even drive it from cold now, I'm having to leave it running for around 10 minutes just to manage to pull off slowly! Sick to the teeth of it.
  1. HELP PLEASE - Trouble codes: P1105-FA and P0105-FA
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 27th November 2015, 14:37
  2. PLEASE HELP!! Error codes p0100 & p0105
    By signum_05 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st December 2012, 13:32
  3. Error codes p1105 and p0105
    By signum_05 in forum Engine & Drivetrain
    Last Post: 3rd July 2012, 12:58
  4. 2 fault codes p0105 p1105 can any1 help??
    By barrymanalow87 in forum Engine & Drivetrain
    Last Post: 23rd September 2009, 09:08
  5. P1105 and P0105 Help?
    By vectra2004 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2008, 00:30
p1105 klaida
feil kode p1105
p0105 klaida
cod eroare p1105
erro p1105 opel
error p1105
opel vectra greska p0105
https:www.vectra-c.comforumshowthread.php177339-PLEASE-HELP!!-Error-codes-p1105-amp-p0105
0105 1105
opel error p1105
p11o5 error code
p1105 vectra error code
Eroare P0105
vauxhall signum codes p1105;p0105 site:www.vectra-c.com
opel vectra kluda p1105
vectra c code 0105
greska na opelvectra c P0105
