Results 1 to 10 of 15
Thread: coolant bleed screw
    May 2012
    Westlothian
    Default coolant bleed screw
    Hi guys i changed my thermostat over as the previous 1 was duff i followed the how 2's on running the system while topping up i've done the motorway run etc still no hot air and gauge not moving unless in traffic and 2.5k revs.
    This evening i trawled the search section again pumped pipes these are hot but easily squeezed i have put CC on Hi and fans on 0 removed the cap and run the car to temp the gauge goes past 80oC as soon as the fans are switched on the gauge drops to 0 again until the fans switched off again
    i cant find a picture of the bleed screw for a 2.2 dti if anyone could help it would be appreciated
    there are 2 plastic screw covers on the silver pipes at the front but im guessing these are the aircon as they have valves inside like you find on a tyre trying to defrost windows with heated seats takes forever lol
    Allan
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Airlock
    May 2012
    Westlothian
    that's what i guessing any input on screw location would be great or best way to get it moving
    May 2012
    Westlothian
    wow guess nobody knows other than the 1 reply to which i had already assumed
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    It should be at front of engine. Plastic screw, i replaced mine for brass bolt with fibra washer and is stronger than plastic which breaks! It'll have rubber hoses clamped with either spring or jubliee clips on each end and extra pipe midway.
    Round and flat with circle around middle nut lookalike and slotted bit. Black.
    The system has a header tank which should eliminate the need to bleed the system, or for it to develop airlocks.
    Any air in the system will go to the highest point - yes the header tank.
    It could be that the replacement thermostat is also faulty. Only way to know for sure is to remove it and see if it's stuck open. If looks ok, put it in a pan of water and bring the water to the boil. It shouldn't open fully until the water is nearly boiled.
    May 2012
    Westlothian
    Well its not going to the fuel tank is it
    total waste of my time reading this comment as its the same as everyone posts maybe if i put the car on a steep hill that will help with any air trapped
    Thanks Humourbash will have a look
    newport
    i just changed the stat on mine the other day, after refilling i ran the engine upto temp, leaving the cap off the header tank and fans on 4 and full heat, once it got to 90 odd, the stat opened, the level dropped in the tank, topped it up again, ran it upto temp, and waited for the stat to open again, topped up a tiny bit more, then put cap back on. car has ran perfect since, nice and warm in the car too.
    did run it with the cap off?
    May 2012
    Westlothian
    Quote Originally Posted by taffy bhoy View Post
    Yeah Taff i done that mate looking for the bleed valve on a 2.2 dti to try that if not will need to purchase another stat. The temp gauge will climb on low fan setting above 80oc if left to run like that it will probably go higher but if i increase the fan the gauge slowly drops to 0 again once the bottom right rad hose is pumped the hose gets hot but after couple mins its cold again.
    Maybe see if it will run to 90oc at the weekend
    Quote Originally Posted by Allan-DTI View Post
    Fair enough if you want to dismiss the truth.
    Makes note not to offer you any help in the future to save myself a total waste of my time, you ungrateful so and so.
  1. Rounded Clutch Bleed Screw
    By Anth92 in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2012, 19:06
  2. cooling bleed screw
    By Alerxt in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2012, 15:34
  3. Whats with this screw
    Last Post: 17th June 2012, 16:54
  4. Rounded off bleed screw - rear caliper
    By 19CDTi in forum Suspension, Wheels & Brakes
    Last Post: 15th June 2012, 10:34
  5. LCD bleed
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 18:49
vectra coolant bleed valve
vectra c coolant bleed
bleeding coolant system Z19dth
2.2 dti bleeding coolant
bleeding radiator on vauxhall vectra
how to bleed coolant system vectra exclusiv
vauxhall insignia bleed bolt location
insignia thermostat bleed nipple
2.2 dti vecyra coolant bleed
vectra 1.9 coolant leak from bleed screw
vectra 1.9 coolant bleed screw leak
vectra coolant bleed screw
where is the coolant bleeding nipple in a 08 zafira
how do you bleed radiator on vauxhall meriva
vectra c coolant bleed screw location
vectra c cooling system
vectra 1.9 cdti coolant bleed screw
vectra c coolant bleed screw size
vauxhall water bleed screw
how to check 1.9cdti for water airlock
vauxhall vectra c change thermostat bleed coolect
how to bleed zafira radiator
bleeding coolant in a vectra 1.9 cdti 07 plate
how to bleed coolant on vectra c www.vectra-c.com
were is the water bleeder valve in a 2000 holden vectra 2.2
