Results 1 to 3 of 3
Thread: Fault Code P1483
    Dec 2012
    Hertfordshire
    confused Fault Code P1483
    I have a Vauxhall Vectra 1.8 petrol 2003 model.
    How do i solve this problem..
    P1483 = Fan Relay 3 Circuit High ORFan Relay 3 Signal Low / Open Circuit
    So the engine management light comes on basically when it feels like and goes off when it feels like it. Plugged my ELM 327 code reader in and P1483 was my error code.
    The air con works, in-car fan works levels 1, 2, 3, & 4 cold air and hot air (though hot air is only ever warmish) and i have checked all related fuses.
    So would be grateful for anyone who can help me with this problem and answer my questions below....
    - where is relay 3 located?
    - is the wiring loom easy to follow and where dose it run along?
    - fan relay 3! what does it ACTUALLY do/control?
    ALSO.. on top of that problem, my oil temperature gauge is intermittent rarely ever works and when it dose its either shows 75'C or 95'C. my code reader always reads about 70'C is this right or should it read about 90'C same as the temp gauge should?
    What do i do about this?
    Would be grateful for any help on these problems
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
  1. p1481,p1482,p1483.
    By jimmyred in forum Engine & Drivetrain
    Last Post: 6th June 2015, 21:41
  2. Code P1481-P1482-P1483
    By Aikon58 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2013, 12:30
  3. Vauxhall Signum Diesel 05 plate fault code P1483
    By cookie01 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th January 2013, 19:28
  4. Fault code help!!!
    By billy88 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2011, 16:02
  5. fault code help
    By delboy2028 in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 21:16
p1483
p1483 vectra c
p1483 opel
vectra c p1483
opel p1483
Opel DTC P1483-04
astra fault code 1483
Opel DTC P1483-4
p1483-04 fan control 3 circuit openp1483 fault code vauxhall1483 opelp1483 vauxhallopel error codes p1483maruthi suzuki dtc name P1483Vauxhall DTC P1483-4eroare p1483-04 opelvectra cvauxhall vectra fault code p1483what would be fault code p1483-06 in a 2006 opel astrap1483 merivavauxhall code p1483https:www.vectra-c.comforumshowthread.php177331-Fault-Code-P1483vauxhall error code 1483p1483 fault code vauxhall merivavectra p1483Opel Vectra C P1483
