Results 1 to 10 of 14
Thread: HID ballast
    Regular Member jamiedvvt's Avatar
    Sep 2012
    Inverclyde
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 1.8 vvt
    Default HID ballast
    What's the best place to mount the HID ballast on the drivers side not much space around the airbox
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I cable tied mine to the air con pipes. If you take the light unit out there should be space on the bottom of the light itself to screw the ballast in where the Vauxhall OEM one would go if you had xenons. Mine didn't fit though so cable tied it to the air con pipes nice and tight.
    Jul 2011
    UK
    Year : 06
    Left hanging next t light lol or under the headlight
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    There's space under the headlight to allow fitting of the ballast. Couple of cableties and some self tapping screws and your sorted. There's 2-3 screw holes underneath the headlamp to put the screws in. Have a look in the How2 section for guidance
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Got the ballast attached to the pipes under the airbox nice snug fit and what a difference i can see at night now
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    just double sided taped mine in the spaces under the headlights for the factory fit ones snug fit out of sight nice and neat, been on now for a few months no probs,but will probably do the cable tie thing in the future just for extra security
    VIP-Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    How warm do the ballasts get when in use? Sure I read somewhere that they are often mounted under the headlamp to help with cooling as the air passes over them.
    May 2012
    rhondda
    mine is tucked behind the air intake pipe
    Barrow In Furness, Cumbria
    Mine are cabletied on the double a/c pipes.
    11 Post(s)
    Quote Originally Posted by MrDerv View Post
    http://www.vectra-c.com/forum/showth...=1#post1060742
  1. How much Ballast? Arrrggggg
    By nibblitz in forum The 'Off Topic' room
    Last Post: 12th April 2012, 08:49
  2. Spare ballast?
    By Barlow in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2012, 01:21
  3. Grounding for HID Ballast?
    By the-converter in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2011, 10:57
