Thread: How to disconnect the radiator fan
    Nov 2012
    Birmingham
    Default How to disconnect the radiator fan
    Evening y'all,
    Having a bit of a problem with disconnecting my radiator fan.
    Basically I've got a damaged water radiator which I'm currently replacing. Now I've taken off one of the screws connecting the fan and radiator. The second one, like an idiot, I've managed to strip it to an impossible point. I thought I'd try cutting a new head, with a hacksaw so a flat blade screwdriver would do. It didn't work.
    I'm fed up of this screw, and have found a used radiator fan from a scrappy for £20, so I can connect it to my new radiator.
    I'm trying to disconnect the wire linking the car to the back of the radiator fan. It doesn't budge off and I can't seem to find some sort of mechanism to disconnect it. Can anyone help?
    Sep 2014
    Eindhoven
    Vehicle : Vectra-C
    Trim : Sedan
    Engine : 1.8 XE
    I am also facing a similar kind of problem, I want to disconnect radiator fan connector and the connector connecting cooling fan module. Its Vectra c 2003 model with single radiator fan. Can any one share how to disconnect these connectors ?
    Sep 2011
    norwich,norfolk
    I believe they have a clip that slides out to enable the plug to be removed.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Im only guessing but it may be the same kind of connector as on a headlight.
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    19 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 216,400
    ^^ Yep. The plug has a sliding component as above. Clean the plug off and you should be able to see it. I think it's red, also as above.
    When I removed mine over a year ago, I teased a small screwdriver in there to get the slide moving. Even being careful, I broke my plug! The two parallel plastic parts still lock the connector in place, though, so I am content that it is secure.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
  1. Intercooler radiator removal without water radiator
    By Whosane in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2012, 15:48
  2. Is it ok to disconnect EGR plug..?
    By Dippy-Vx-line Red in forum Diesel Engine related
    Last Post: 6th June 2012, 17:05
  3. Alarm disconnect
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2010, 20:47
  4. Disconnect battery?
    By yoclick in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2009, 09:46
  5. Will I need to disconnect my battery
    By ballmonkey in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2007, 14:37
how to unclip cooling fan vectra c
