Thread: dose anyone have the same problem
    Oct 2012
    wrexham
    Default dose anyone have the same problem
    i fitted my hids on sunday and im having a problem with the driver side bulb popping out as the bulb is a little thicker than standard. has any one eles had the same problem?
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Sorry, can't help with yor question, but can I ask what kit you bought and if you are talking about plastic based bulbs or metal?
    I'm contemplating a set myself, so would be handy to know of any potential pitfalls.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Not had a problem mate its bulb holder ok?
    Oct 2012
    wrexham
    my hids are plastic based i cant rember i had them in my old vectra b
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Need to get some bulb holders an cut them to fit around wire then they will fit in correctly
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by Critch View Post
    Think the OP has a facelift so won't have bulb holders - seems strange how only one is popping out, can they be filed down a bit? (bulb bases).
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Aahh my bad.
    in that case I'd be making sure the lugs are ok in back of the light unit.
    the problem must lie with that bulb/ light unit if its only that one doing it
    Sep 2010
    I've had both plastic and metal base bulbs on my HIDs... just get another set of bulbs with metal bases (HIDS direct are metal - HIDS4US are plastic) - I found both a good fit tho.
    11 Post(s)
    My HIDs have plastic bases and have never popped out the headlight clips in the 3+ years fitted.
    Make sure the bulb is seated correctly, and the clips aren't bent. Probably best to take the headlight out to check up close. Bumper off job though. Approx 15 mins to do.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    When I fitted mine into my Facelift the clips that hold the bulbs in were not that easy to close as where the wires come out the rear of the bulb were covered by a large piece of heatshrink sleeve (as in pic below borrowed from google) so had to bend the clips a little harder to hold bulb in place. Got there in the end though
  1. what dose everyone think of this
    By matt450 in forum The 'Off Topic' room
    Last Post: 25th September 2011, 19:42
  2. dose any one no what these to plugs are
    By davidxr20 in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2011, 14:08
  3. dose any one no what this is
    Last Post: 13th February 2011, 23:19
  4. Dose anybody know???
    By welshboy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2011, 02:16
  5. Dose Any1 Know ???
    By neil3734 in forum The 'Off Topic' room
    Last Post: 17th March 2009, 16:39
