Results 1 to 3 of 3
Thread: top mounts and shocks
    kent
    Default top mounts and shocks
    Had a spring replaced as part of the MOT and now ive got a horrendous clunk when going over bumps.
    Ive changed the anti roll bar links and still the clunk. From reading through the forum it appears to be the top bearing.
    Ive decided to replace the lot, shocks, bearings and mount on both sides.
    Can anyone recommend where to buy this lot from, also a decent set of spring compressors that wont break the bank, moneys tight due to Christmas.
    Cars an 05 diesel estate
    thanks
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Make sure spring is sat and located properly.
    halfords spring compressors are about 20 quid
    kent
    Ive had a look as best i can, the spring looks like its sitting ok. I've just noticed tonight that i creaks when i turn the steering wheel when stationary. Before the spring was replaced there was a knocking but not as bad as it is now.
    I think i'm going to strip it down, replace the bearings and top mount and see it that makes a difference.
    Any recommendations on where to buy the parts from
  1. Rad mounts
    By big tee in forum Suspension, Wheels & Brakes
    Last Post: 17th February 2013, 21:54
  2. Top mounts
    By RBH in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2012, 07:49
  3. rad mounts help
    By n8sby in forum Suspension, Wheels & Brakes
    Last Post: 16th March 2011, 10:21
  4. rad mounts
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2009, 22:50
  5. rad mounts
    Last Post: 11th December 2008, 13:42
