Results 1 to 10 of 21
Thread: found my noise -- help needed
    Nov 2011
    devon
    Vehicle : vectra 1.9 cdti
    Trim : sri
    Engine : 120 8v
    Mileage : 84000
    Default found my noise -- help needed
    my old thread from last week regarding an intermittent noise started again earlier.this time i was went to my mechanic who said it sounds like the bearing pulley on the alternator? its the freewheeling aspect as it started when we slowed down and goes when you rev up,so makes sense,so bearing is on way out.
    first thing,how difficult is it to get the alernator out,as he said he will get the pulley off and wont charge me if i take it to him.
    second is whats the part number for the pulley anyone.or if its meant to be a full alternator ,where can i get a pulley other than vx?
    and how long should i keep driving it.it went away again so obviously isnt completely shot ,YET?
    May 2012
    UK
    What kind of noise is it?
    Sep 2010
    Quote Originally Posted by Chip View Post
    chirpy cheep sheep grind by the sound of it on throttle
    http://www.vectra-c.com/forum/showth...t-noise-120-8v
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    on some cars its easier to remove the offside intermediate driveshafe to drop and remove it, but that was on a 2.8T
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    the pulleys are pretty expensive to buy on their own, you be best either finding a alternator repairer or getting a second hand one m8
    Engine : 1.9 CDTi
    What engine do you have as there is a guide showing how to remove one from a diesel.
    Nov 2011
    devon
    Trim : sri
    Engine : 120 8v
    Mileage : 84000
    sorry guys ,its a 1.9 120 . what sort of time span am i looking at in terms of driving it? if the alternator can be done without the driveshaft i will have a go.i can probably get the mum in laws car for a couple of days. in terms of noise,once i put it under load it clears it up.as i tried to explain above,the way it was described to me ,it does make sense,if its freewheeling when it makes the sound but goes away when you put the car underload.he seemed pretty sure that was the problem,the bearing starting to break down and he has done a few so knew the noise..
    i havent sorted my trade card yet either ffs,so gona have to pay full whack.
    if anyone has any ideas let me know,but frankly whats the point of changing the alternator if it aint shagged?
    Nov 2007
    lancashire
    should only take an hour to take out at most, 64 quid was prise i got for pully alone or 95 for a replacement altinator no drive shafts need to be removed just air box and the small inner wheel arch cover which needs to be removed to take the fan belt off.. had 5 of these pullys break up on me ( 282.000 miles) but strange thing is that when my crank pullt delaninated( rubber bits holding the two halfs together) i repaired pully by welding it so it was a solid pully and not a damped pully and since then no more broken altinator clutches i think there must be some sort of strange resonance going on with the damped pully causing the clutches to break up!!!!
    Nov 2011
    devon
    Trim : sri
    Engine : 120 8v
    Mileage : 84000
    Quote Originally Posted by taxidriver50005 View Post
    so from your vast knowledge due to mileage, does this defo sound like the alternator pulley thats causing it? also how long were you running the car for till you replaced them each time? and where did you manage it for £64 lol, cheers
    Engine : 1.9 CDTi
    I have the same noise that comes and goes (Worse in the summer) and been doing it for 20k miles.
    Our local refurb place fits non free wheeling ones as its not really needed. Just helps take the load off under deceleration.
  1. Help needed. Noise from rear of car.
    By 123rado in forum Suspension, Wheels & Brakes
    Last Post: 3rd January 2011, 15:58
  2. Whining noise - help needed
    By b17e30 in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2010, 08:22
  3. i found what the knocking noise was lol
    By redraptor_141 in forum Suspension, Wheels & Brakes
    Last Post: 20th March 2009, 21:06
  4. Help needed please knocking/banging noise
    By phil67 in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2008, 15:46
  5. Interior Trim - Needed and not found!!
    By breeza in forum Bodywork & Interior
    Last Post: 4th February 2008, 16:58
