Thread: Tyre pressure
    Regular Member jamiedvvt's Avatar
    Sep 2012
    Inverclyde
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 1.8 vvt
    Default Tyre pressure
    What is the correct tyre pressure for 215/50/17 i'm currently running 32 psi at all four corners 1.8 sri Thanks
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    About 36psi should be right.
    The general rule is 2 x diameter plus 2psi. = 36pi.
    Sep 2010
    The manual states for a 1.8:
    29psi front / 32psi rear for normal driving / load
    35psi front / 38psi rear for eco driving
    35psi front / 42psi rear for driving with heavy load
    http://www.vauxhall.co.uk/content/da...nual_Jul07.pdf
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    I have always done double the rim size +2 and it has always served me well in the past. But having just fitted 2 new tyres to my car I found that it was too much, made the front far too light, when it had been perfect for my old NCT5's. Through a bit of trail and error I found 33 psi gave best feel and handling.
    Sep 2010
    I run 33 on the 17"s fitted to the other SRI, my XP2 is running 34psi. The 2xdiameter + 2 would require 38psi which I consider a bit too high and as Das says,.. feel too light in steering.
    May 2012
    UK
    Do the eco settings actually work?
    Sep 2010
    Quote Originally Posted by Chip View Post
    It must have some effect as there will be slightly less tyre contacting the road. I might put mine up to 36 and see how it fares. Just running the Shell V Power test to see if it's worth the extra pennies,.. on 3rd tank now so see if I get more mpg
  1. Tyre Pressure?
    By Knuckle in forum Suspension, Wheels & Brakes
    Last Post: 31st May 2011, 07:21
  2. what tyre pressure??????
    By dannyjpuk in forum General Chat
    Last Post: 6th March 2010, 21:27
  3. tyre pressure
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2009, 10:30
  4. tyre pressure for GSI
    By effone in forum Handling & Braking
    Last Post: 7th December 2008, 06:07
  5. Tyre pressure
    By EARLEY in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2007, 18:41
correct tyre pressures for a Vauxhall Vectra C 1.8vvt 2008
vectra c sri tyre pressure
vectra c tyre pressures sri 1.8
2007 vectra 1.8sri tyre presure
tyre pressure vauxhall vectra c 1.8 vvt
vectra c 1.8 tyre pressure
what is the tyre pressure for vauxhall vectra 1.8 nav
