Thread: Intake Air Temperature Sensor - Where is it?!
    Apr 2011
    Darlo
    Default Intake Air Temperature Sensor - Where is it?!
    Just wondering if any one knew? googled it and nothing much comes up, have a fault code p0100 intake air tempterature sensor circuit malfunction
    its a 55 plate cdti 1.9 engine
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Forum searches all point to the airflow meter for P0100 Yates. Not where i originally thought it was on the manifold when we had a look at it.
    It's the Plastic pipe with a wiring connector on it attached the the top part of the air filter housing. Check the connection is secure, might be worth disconnecting it and cleaning the terminals while you're at it. If that doesn't fix it, it's new airflow meter time
    Apr 2011
    Darlo
    aye you said mate, but googled it and nothing much, just looked online and they are about 150 mate, altho just found one for 36 quid, didnt want to spend 150 if thats not it. its disconnected at moment and cleaned up, just thought id ask in case we both totally had wrong thing. cheers for help again
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Do you know anybody with the same motor you could try theirs on your car that would tell you if yours is faulty,I think that makes sense
    Apr 2011
    Darlo
    nah dont know anyone
  1. Temperature Sensor?
    By JaceyBoy in forum Engine & Drivetrain
    Last Post: 18th May 2012, 21:52
  2. outside temperature sensor
    By luke.oldham in forum Electrical & ICE (including SatNav)
    Last Post: 27th May 2010, 00:07
  3. intake air temperature sensor 1.9 16v CDTi
    By si_sri in forum Engine & Drivetrain
    Last Post: 26th April 2010, 13:27
  4. outside temperature sensor
    By billyyoung in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2008, 17:23
  5. Outside Temperature Sensor U/s
    By turnerk in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2007, 22:05
