Thread: fitting aftermarket rear parking sensors , best way to get into boot?
    newport
    Default fitting aftermarket rear parking sensors , best way to get into boot?
    ive fitted them before on my old car, but the last car had a towbar that i removed so had a hole i could easily access to pop the wiring into the boot. this one hasnt had one, so where do you people get the wiring into the boot if you dont take the bumper off (which i wont be doing)
    thanks in advance
    Jul 2011
    UK
    Year : 06
    done a camera today for reverse take the trim of the boot the plastic bit and down to the left u will see a rubber grommet just pit the wire through there I jacked the rear up to get under the car better to feed the wires
    Regular Member Matt_NI's Avatar
    Dec 2011
    N. Ireland
    Can I ask, do towbars affect rear parking sensors?
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    Quote Originally Posted by Matt_NI View Post
    No, Fitted mine with towbar on. No problems.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Removal of bumper: http://www.vectra-c.com/forum/showth...oval-Replacing
    Fitting of sensors (including wiring through bodywork): http://www.vectra-c.com/forum/showth...ersing-Sensors
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    No need to remove bumper fit wiring through grommet for number plate lights
    Sodding Typical on Sea
    Quote Originally Posted by troutybrown View Post
    If you do remove the rear bumper you can use the factory markings for placement of the sensors though
    newport
    i am not removing bumper, i used the measurements on here to mark the bumper from the outside, it worked perfectly
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Quote Originally Posted by azacbr6 View Post
    I've got rear parking sensors with a tow bar. When you reverse with out towing anything the sensors stop you about 1 ft. from the object. The tow bar might only be 6" away from the object, so you do need to be careful when parking up against another car.
    When you reverse with a trailer/ caravan and engage reverse, the sensor picks the trailer up and the buzzer flat lines immediately as thou you are 1ft away from something. You could probably get a switch fitted to turn them off, but I haven't and its not often when your towing that you have to reverse.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Quote Originally Posted by Derek Mc View Post
    Use the measurements on the how to and they are same as factory
  1. fitting aftermarket rear parking sensors to full canbus, any issues?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2012, 10:41
  2. Fitting aftermarket parking sensors to XP 'd rear bumper
    By 2.2 oil burner in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2012, 22:45
  3. fitting aftermarket rear parking sensors
    Last Post: 9th September 2011, 19:45
  4. Fitting rear parking sensors to Honda jazz ..HELP!!!!
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2008, 10:54
  5. Rear boot spoiler & parking sensors
    By ballmonkey in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2007, 21:35
