Results 1 to 10 of 13
Thread: hey guys new here and have a question
    Nov 2012
    cumbernauld
    Default hey guys new here and have a question
    I just got myself a 2004 veccy nice car if i say so myself. No history on the timing belt so I baught a timing belt kit from vaux center and also got a water pump its all fitted on.
    But there is a problem the belt tention arm isint moving at all the belt is the same size and the water pump is right and the tensioner looks the same. The old one got grinded off cause the bolt crumbled. I checked my order with the epc and seems right. epc says 93185845 for the kit and so does the order. The water pump was right as well. Now I guess im asking if anyone knows if the FAI TB156 is the kit for 93185845 or will I need to buy a seperate tentioner. I cant see it being anything else thanks in advance grant.
    ps seen the thermostat howto and done it smashing right up car is lovely and warm obviously I dont want to drive it about with the tensioner like this is there some sort of black magic to get the tentioner to tights the engine is a z18xe thanks for reading a long story.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    you cannot set the tensioner with the allen key to the 20mins past position so that the arrow points to the new belt position? This can be tricky to set, you have to set it and then get somebody to tighten the torx stud up in the tensioner pulley to get it to stay whilst you hold the allen key keeping it in the new belt position. Maybe you have already tried this..
    Nov 2012
    cumbernauld
    Well thats the problem I twist it right round and the tenstion doesnt go up only a little not even to the used belt. Ive ordered a new tensoner from ebay cause the other one isint usable as the nut was grinded off. I hope this works out if not I have no idea what the problem is. Hopefully it was just a mixed up part at packing. Cause the other two pullys are the right size.
    Jun 2009
    South Coast
    Are you using genuine GM parts?
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    Quote Originally Posted by grant2258 View Post
    Sounds more like the belt is fitted incorrect
    Nov 2012
    cumbernauld
    using a fai kit tbk156 from vauxcentre its listed as the right kit http://www.ebay.co.uk/itm/Vauxhall-A...item35b2599b22 I think its the wrong tensioner so ive ordered http://cgi.ebay.co.uk/ws/eBayISAPI.d...E:L:OC:GB:3160 the part number i have got from the orignal tensioner is 24426500
    Jun 2012
    lancashire
    have you checked you have run the belt correctly round the pulleys?
    Nov 2012
    cumbernauld
    belt is definatly on the right way wasnt the esiest belt to get on Will take picsnext weekend. Does anyone have any pcs of how the belt should be run on the z18xe it was put on the same was as the one that came off. Is it possible to put it on wrong?
    Jun 2012
    lancashire
    Jun 2009
    South Coast
    the last tensioner looks right, odd that it is a different colour to the one in the first kit...
    John, its obvious when doing the belt on these which way they go and they can't really go any other way..
  1. MOT question NI guys only
    By aerodynamic18 in forum Northern Ireland (RO - Vacant)
    Last Post: 8th February 2010, 22:46
  2. question guys
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2008, 19:28
  3. Oil Question(sorry guys)
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2008, 22:06
  4. Question for any I.T. Guys out there
    By Merick in forum General Chat
    Last Post: 26th April 2007, 09:29
