Results 1 to 10 of 13
Thread: rear disc removal
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default rear disc removal
    What size torx do i need to get the caliper of the rear of 04 2.2 dti. Front i know is e20
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I believe its the same mate. Linky
    Regular Member shane31's Avatar
    Sep 2011
    Staffordshire
    E20 buddy.. Mine were really tight had to get breaker bar on.. And unlike the fronts the hub dont turn so doing it on the floor was a pain in the pants good luck and enjoy..
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Mine was E18 on the rear...
    Im sure the bolts on my car were e18 as well, they loosened off a lot easier after using a bit of heat to soften the thread locking compound. The fronts were e20 bolts though and i guess the e20 socket will grip the e18 head on the rear but not as snug a fit as the e18 socket
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    E18 on the rears, E20 on the fronts. Rears will be TIGHT if not done before, spray with plus gas and use a long breaker and you will be fine. Wrong size socket WILL knacker the bolt head.
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Id best find a heat source then. Any ideas. Dont have a blow torch
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    well i admit defeat, got the sockets, and a long breaker bar, 3 ft long, and they wont budge, ive broken 2 sockets, so off to the garage it will go. if they break a few tools its their problem
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    I've just the same bit of work...
    They are a pain the butt, and you are turning them the right way??
    Mine came off in the end though, a lot of WD40, Foul Language, and pulling on a breaker bar.
    I think they are 96lb/ft...Fronts are 170!!
    Matt
  1. 4 disc changer , cartridge removal ?
    By biffbangpow in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2013, 01:30
  2. Rear disc removal nightmare
    By Bigbaw in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2012, 15:08
  3. Rear Disc Dust Shield Removal...
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2010, 15:36
  4. rear disc and pad set ????????
    By mark the hat in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2008, 19:31
  5. Rear disc & pad set
    By yorkshireborn in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2008, 22:18
