Results 1 to 10 of 14
Thread: Only one pipe smokes
    Regular Member Angel1368's Avatar
    Mar 2012
    liverpool
    17 Post(s)
    Trim : VXR
    Engine : 2.8 V6 turbo
    Mileage : 44,000
    Default Only one pipe smokes
    Just noticed only one of my twin pipes smokes when at standstill in cold weather, when its moving its both but at a stop just drivers side, very odd
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    maybe to do with path of least resistance
    Mar 2012
    liverpool
    17 Post(s)
    Trim : VXR
    Mileage : 44,000
    thats what i thought but after having a look they look symetrical, down same pipe then y piece split then back boxes
    Regular Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    mine does it mate and then when revved get it out of two you are getting it out off both but ones as said like the path of less resistance
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    i have this issue with my custom system we ( me and the fabricators) know what the issue is and are gonna sort it but as dean says it will follow the path of least resistance when one pipe can flow enough to not cause a restriction(back pressure) buildup, when your driving the amount of gas increases and the back pressure caused equilises the flow
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Mine smokes out of all 4
    Dec 2011
    liverpool
    6 Post(s)
    yours would wouldnt it hahaha
    Quote Originally Posted by plasma View Post
    Shouldn't be
    The Vectra C has a basic and simple system which simply splits the same single output
    Therefore it suggests the internal baffles in the affected rear silencer have either failed or collapsed
    Banging the underside will confirm if this is the case
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    The rear boxes are different sizes, and in fact some right hand sides of the Y section have a smaller bore. This promotes less flow from the right hand side, this is how it worked on my 2.0T system anyhow. Where as with the Irmscher Y section and the Irmscher Quads all 4 pipes smoke the same as both sides of the Y section and both rear boxes are Identical.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    All four of my Irmy pipes smoke
  1. 2.2DTI smokes heavily on start-up
    By jammy_c in forum Engine & Drivetrain
    Last Post: 15th October 2012, 17:06
  2. Whos car smokes tunning box or remap
    By marc vectra sri in forum Diesel Engine related
    Last Post: 6th August 2012, 21:48
  3. Replies: 5
    Last Post: 17th January 2011, 09:12
  4. Replies: 0
    Last Post: 30th September 2010, 19:11
  5. 1.9cdti smokes when at 80 mph
    By alkez100 in forum Engine & Drivetrain
    Last Post: 24th April 2010, 00:04
