Results 1 to 10 of 16
Thread: CDTI - Boost Solenoid
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Default CDTI - Boost Solenoid
    Anyone any pics of their engine bay and how the a boost solenoid is bolted, seems to be 2 bolts and a bracket next to the passenger light?
    Also where can I pick up a new Vac pipe? The one on is too short, quick bodge to get it going, seems my boost solenoid went walkies while its been stood in the garage
    18 Post(s)
    Mileage : 110k
    Anyone, will stealers do them... Are they 4mm internal diameter?
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    mmm, not a reply on this one, lemme see if i can help...
    thinking about it, yes it is bolted near to the nearside light, and is held to the slampanel by two nuts, you should see two outlets sticking out from it where the boost hoses go.
    If your hose is too short you can get yourself some silicone replacement from ebay with 4mm ID as you say.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    18 Post(s)
    Mileage : 110k
    Sound, think someone mentioned the location in another thread, I'll pick up a 4mm ASAP, what's the nut size as there is non on the 2 bolts located near the rad
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    will have a checky, for you, from memory the size is something like M4
    checked it out. assuming 1.9cdti
    11086223 20 64 892 NUT, HEX., M6, BRACKET,
    18 Post(s)
    Mileage : 110k
    Awesome thanks... Failing that I'll go for a walk around some scrap yards this weekend
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    It's mounted on rubber bobbins. My threads were so rusted that the rubber broke long before the nuts. Going to remove the rubber from the bracket and re-mount with 2 of these (or similar): http://www.ebay.co.uk/itm/380522153090
    Got myself a new one from here: http://www.courtenaysport.co.uk/buy-...prod_1091.html. Incidentally, this seems to have cured the judder/hesitation/misfire between about 1500-2000 revs (touch wood) but note that the pipes come off at a different angle to the original. Also got some eBay 4mm silicone tubing. Nuts are (were) 10mm so threads should be M6.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Some pics here - if you need any more let me know and I will go and take a photo of mine http://www.vectra-c.com/forum/showth...-1500-2000-rpm
    18 Post(s)
    Mileage : 110k
    Quote Originally Posted by plasma View Post
    Is that a link?
    Quote Originally Posted by alcutler View Post
    Some picks here - if you need any more let me know and I will go and take a photo of mine http://www.vectra-c.com/forum/showth...-1500-2000-rpm
    Cheers, did you use 4mm for the hose
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by leemarksmith View Post
    Yes, the blue pipe is 4mm internal dia silicon tubing
  1. boost control solenoid
    By viper8 in forum Engine & Drivetrain
    Last Post: 14th January 2013, 00:22
  2. boost control solenoid
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2012, 13:45
  3. Turbo boost solenoid part nos 2.0t
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2011, 12:53
  4. Does this sound like a faulty Boost Solenoid?
    By mally in forum Diesel Engine related
    Last Post: 23rd June 2010, 18:35
  5. Sound like Boost solenoid?
    By mally in forum Engine & Drivetrain
    Last Post: 22nd June 2010, 19:19
