Results 1 to 10 of 28
Thread: Still boost issue!!!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Still boost issue!!!
    I replaced intercooler hoses, checked all seals. All good. Oil filter and castrol magentic 5/30 oil put in.
    Tried same as before to see if boost is back to normal then car with spanner lit up!
    Getting annoyed now. Its not the hoses. What else could it be??? That cause loss of power as in starved of air! Then car runs normal after 10 seconds.
    Idle is way smooth now with expensive oil in!!! Its 5/7 as i didnt want to put max oil in and above middle for best performance!
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Not sure how you equate a smooth tickover with expensive oil not got ought to do with it perhaps changing pipes on the mixture side has actually improved things. Have you checked the boost valve? And the front boost vacuum unit?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Idle is a lot better after oil change due to really sluggy thicker than thick oil and filter really clogged up!!!
    Wheres this vaccum thing? And the boost valve? So i can check. I need someone who had same issue and see what fixed it for the car. Photo helps :-)
    23 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Check the how 2 for the boost sensor but its on the back of the inlet manifold next to the egr the vacuum unit is on the front scuttle panel with 2 rubber pipes going to it. Run the engine and pull a pipe off and see if it hisses as air rushes in when the vacuum is broken if not check the rubber pipes connected to it they are well known for leaks and therefore no vacuum or turbo boost
    23 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    If the oil was that bad did you do an engine flush?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    2 new silicone hoses to booster sensor. Boost sensor took apart and cleanted through.
    Will look at this vac pump. But can feel rushs of air pass through. But will check.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by paulhb View Post
    I put clean oil through and drained. New expensive oil in now,
    23 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    It's not a pump just a vacuum chamber have you any fault codes showing check the replaced pipes are on tight no leaks
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Checked all pipes, all tight, no leaks!
    Brother in law suggested air meter. Could that cause issues?
    No fault showing on reader.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Anyone? I will check vacuum pump, recheck boost sensor connections, maf, what else should i look for? So i can check check check without going back to check for something else.
    All in one go!
    What else should i check?
  1. Boost issue on sri cdti 150.
    By Mason300 in forum Engine & Drivetrain
    Last Post: 18th October 2010, 08:23
  2. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  3. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
  4. 2.0T Boost Issue - Help Please
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2009, 19:22
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
