Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: Not happy with mpg
    Regular Member gaz1965's Avatar
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    Default Not happy with mpg
    Hi all as said above. I have a 1.9 cdti 150. On my journey to work today which is through traffic as well a dual carriageway my average mpg was showing as 23 mpg. Not happy at all I wasn't driving her hard. I have noticed it getting gradually worse lately. She has been serviced recently and she drived lovely. Any ideas? Oh she was registered on 12/06/07 does anyone know if I have the updated swirl bar?
    Gaz
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    It will have missed the new manifold by about 7weeks I wreckon.
    Regular Member shinyb1's Avatar
    Jul 2011
    wigan
    the dpf could of been doing a regen , my mpg drops when mine does it .
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    The weather, it's cold so the engine takes a little longer to warm up so mpg will be bad until car is warm, you have the heaters on to keep you warm, your lights are on more than normal. My MPG which in the summer was sitting around 47-49 has dropped to 43-44, and that's after a regen. I'm putting down to the cold weather.
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    Thanks guys. Excuse my ignorance but whats a regen? :-p
    Sep 2010
    Quote Originally Posted by gaz1965 View Post
    Only have a DPF if you have a Signum or an estate so looking at your avatar (Hatch) this won't affect you. Mpg drops in the winter months but 23 seem about 50% of what you should be achieving.
    Check tyre pressures and simple things first. Make sure your air filter has been replaced and not clogged up with small leaves.
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    Thanks Chewy had a service about 2000 miles ago. Would cleaning the egr valve halp?
    Middlesex
    Trim : SRI
    Mileage : 100k
    Does your car get warm (temp needle) and stay over 85 degrees. THis cold weather shows up a lot of failed thermostats which if failed open as they do - will mean you are running the cold map a lot longer.
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    I reckon its that because she takes ages to warm up and the temp usually stays below 85
    Middlesex
    Trim : SRI
    Mileage : 100k
    It will be then.
    The car should warm at stay around 86 - 90 degrees regardless of driving.
    New thermostat comes in a complete housing and includes the CTS.
    Ideal time to flush the coolant aswell.
  1. Full Hunter alignment - One very happy member and one not so happy
    Last Post: 14th April 2012, 14:08
  2. She wasn't happy
    By dannyjpuk in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2011, 09:27
  3. Job done and happy out
    By MURDO in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 21:54
  4. HID Happy :)
    By kirky2k4 in forum Styling
    Last Post: 4th February 2011, 23:37
  5. I'm happy..........
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2008, 09:47
