Thread: problem not starting
    Regular Member neil52's Avatar
    Oct 2012
    leeds
    Default problem not starting
    I have a problem with car starting, was turning over but now wont just a clicking noise when turning key, ive had RAC out they couldnt get it started he said sounds like starter motor and also a fuel issue. were is the fuel pump situated on the car, the rac chap said it was in the fuel tank ?.is this right
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    3 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Could also be the battery? What engine do you have a that could help with responses, hopefully isn't the starter motor.
    Oct 2012
    leeds
    sorry, 2003 2.2dti signum. its a new battery
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Fuel pump is on the engine below the intake manifold on the DTI. It doesn't have a lift pump in the fuel tank
    Nov 2011
    post removed
    Regular Member veclee's Avatar
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    is the battery now flat ? and the rac are only anygood at getting you towed i know i used to be a recovery driver the most common response was its not poss to fix at roadside well get you recovered to nearest garage
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I wouldn't trust rac tbh had car recovered other day (Mazda 6) surposed fuel pump fault I put 15 litres of diesel in an funnily enough if you run a car with no fuel it won't go lol. Once filled up test drove an no fault found.
    anyway enough of that because I'm in middle of applying for job with them lol
    whats your battery voltage? What voltage at starter? Try at relay if you can't get to actuall starter it got a good solid voltage try tapping relay whilst trying to start
    Oct 2012
    leeds
    Quote Originally Posted by Critch View Post
    the rac put his meter on said it was fine im not sure of voltage he said it was just below 13 when he put it on the battery. he really didnt do a lot he wanted to take it to nearest garage but on a sunday nothing really open. i told him once i have starter motor sorted i would ring back in. ill wait till day off and have a further look into starter motor.thankyou for answers.
  1. starting problem
    By tiimi in forum Vectra C / Signum Troubleshooting
    Last Post: 25th October 2012, 20:32
  2. Starting problem
    By trace in forum Insignia car chat
    Last Post: 7th April 2010, 07:18
  3. Problem...? Vectra SXI...problem with starting after filling with fuel?
  4. Starting problem
    By DerekFB in forum Engine & Drivetrain
    Last Post: 19th August 2008, 19:54
  5. starting problem
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2008, 13:09
vectra c not starting after filling with petrol
