Thread: brakes question help needed please
    Regular Member rickeys16v's Avatar
    N.Ireland ( Broughshane )
    Vehicle : 1.9 CDTI 150
    Trim : SRI
    Mileage : 46000
    confused brakes question help needed please
    i have just fitted new pads on the back but to get the piston back in again i had to take off the pipe that brings the brake fluid into the caliper when i rewind it all squirted out... hot do i get the fluid back into it or how do i bleed the system... i will have to go to halfreuds later for some fluid which will i get...
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Need to bleed system
    either get someone to pump pedal while you open bleed nipple ( ensuring the level doesn't drop below min in resevoir)
    or buy an easy bleed then its just a case of opening bleed nipple one at a time (furtherest away from resevoir first) until no air bubble come out
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    You should never need to take pipes off just to push the piston back bud.
    Get a proper windback tool for next time. They're worth it.
    Windback nice and slow so you don't damage the seals in the master cylinder.
    Two-man method is IMO the best way to bleed.
    You need a clear pipe on the bleed nipple and a mate/missus.
    They put pressure on the brake pedal and you open the bleed nut. They push the pedal slowly and steadily down but before it is fully down you tighten the nut so that no fluid goes back in. They release and you repeat the procedure until no bubbles are seen or if you are doing a full change til you see clean fluid in the pipe. Take care to keep the reservior full. Do front right then rear left then front left then rear right.
    Cheers.
    Regular Member conman's Avatar
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    Quote Originally Posted by Yugguy View Post
    I thought when bleeding the brakes you started with the one furthest from the master cylinder which is rear n/side then rear o/side, front n/side and then front o/side.
    Sep 2012
    Engine : 3.2
    Quote Originally Posted by conman View Post
    you're probably righ I always get that bit wrong.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    It's always good practise to start furthest away an work in ensures all air is ok the system.
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    Brakes are a funny thing....lol Fed up with mine at the min, just ordered 2 new rear calipers and hopefully these will sort out all my problems.
  1. Feedback needed: EBC Brakes
    By Alex the Russian in forum Handling & Braking
    Last Post: 9th September 2011, 23:03
  2. Replies: 14
    Last Post: 3rd September 2011, 20:23
  3. Advice Needed : Siggy 2.0t Front Brakes.
    By Envy in forum Handling & Braking
    Last Post: 12th August 2011, 09:24
  4. brakes question
    By jb-redbull in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2010, 10:08
  5. Urgent help needed RE: Rear brakes
    By tempo in forum Suspension, Wheels & Brakes
    Last Post: 10th June 2007, 23:03
