Results 1 to 10 of 16
Thread: Heat issue 1.8 '03
    Regular Member Tinks's Avatar
    Jan 2012
    Whittlesey
    Vehicle : Vectra C Elegance
    Engine : 1800
    Mileage : Lots
    Default Heat issue 1.8 '03
    Hi all,
    Before its said I / we (Caveman Nige) have been through the other posts with similar issues and checked all that's mentioned and in addition to that there is no "outcome" post.
    Ok, firstly many thanks to Nigel for giving up his time yesterday only to be left with a head scratcher!!
    The symptom : intermittent reading on the temp gauge and blowing cold air from the vents.
    What we done : Drained coolant, complete coolant flush, replaced radiator (needed as rad was knackered), replaced stat, replaced coolant.
    Ran engine, no air locks, water leaks, all pipes secure and hot water running through them, matrix pipes have heat in them.
    Still no heat in car!!
    Checked forum, checked behind L/H/S centre console for the red heater servo thing - this moves when the dial is adjusted. The temp gauge works / moves and the fan cuts in where it should.
    This said, there was minimal heat from the screen vents on the 70 mile journey home but only when the speed was on number 1, if turned up to 2 then the fan got quicker as expected but the heat was greatly reduced. When changed to the lower / footwell vents then almost no air movement at all.
    Any help would be greatly appreciated by me and Nige!!
    Tony
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    I had a chat with Paul about this last night mate, he thinks you may still have air lock.
    His suggestion is to run the car again without the header tank cap as we did but this time to get it hotter. He suggests that you need to get the temp to above 100 degrees to make it boil so force out any further air locks. With the cap on the system is pressurized and boils a ta higher temp. To acheive this you will need to run it up to temp without the cap and then use the throttle pedal and give it some revs.
    Obviously you want to do this while the car is stationery as we did yesterday.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Regular Member veclee's Avatar
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    i changed my stat yesterday after 15 mins on the drive idling i still had no heat in the car so i gave it a 3mile thrashing and it cleared the air locks and they say a 2.2 frontera is a b#"*h to bleed and ive done 2 of them before worth a try ?
    Jan 2012
    Whittlesey
    Engine : 1800
    Mileage : Lots
    Nigel and Paul - will give that a go today.
    Trouty - that'll be the next attempt!! cheers for the link
    Veclee - I took it for a not so slow run home for 70 miles after running on Nigels drive and still the same when I pulled up at but cheers for the post.
    Tony
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    The other thing i always do is fill up coolant through a small funnel so it fills slowly to give air a chance to escape
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    did you change just the stat or the full housing? ive seen on here that the housings wear away around the stat and let them leak around ? but sounds poss a faulty stat has been know for them to be new but still not work have you tested it in hot water to check when it opens and its not opening to early you only need it to stick open a fraction for it stay cold the frontera 2.2 petrol is prone for boiling the engines and doing the h/g in so i ran drilled (only 4mm) stat in the sumer help keep it cool and standard stat in the winter and when the fisrt light frost cold days startd i had to change to the standard cos it would only get warm when stuckin traffic then when colder the faster the truck/fan speed so the slightist ill fitting or opening early would show as the symptons your saying hth
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    The complete thermostat housing was changed.
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    my only last suggestion is was the heater matrix rad flushed out in both directions form top and bottom with a hose pipe other than that im about out and as confussed as you
    Jan 2012
    Whittlesey
    Engine : 1800
    Mileage : Lots
    OK people - beginning to think my car is messing with my emotions!!!
    Just took it out for a quick run up the road (3 mile round trip) and I have heat pouring into the car on all fan speed settings!!!! Temp goes to 90+ and the fan comes on, the gauge works and I had a warm journey for the first time!! confused . com.
    Can only think if there was a small air lock then it may well of cleared on this attempt. I will keep you all posted if any further issues with this arise.
    Thank you to you all for you input, really has been appreciated.
    Tony
  1. Windscreens - Heat absorbing or heat reflecting?
    By Caveman_nige in forum General Motoring Chat
    Last Post: 4th February 2013, 22:09
  2. Still no heat
    By wright8672 in forum Engine & Drivetrain
    Last Post: 21st January 2013, 17:51
  3. heat pad
    By male 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2012, 15:09
  4. we have heat at last
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 17:53
  5. No heat
    By schmuh in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2009, 23:36
