Thread: 04 Signum 2.0 DTi giving P0105 and P1105
    Regular Member portreathbeach's Avatar
    Jan 2012
    Cornwall
    Default 04 Signum 2.0 DTi giving P0105 and P1105
    My '04 Signum 2.0 DTi keeps giving me error codes P0105 and P1105 and the car is in 'limp' mode. It only used to happen occasionally, but last night I drove a few colleagues to a works do (about 25 miles) without any problem on the way, but on the way back the car went into 'limp' mode about 10-15 times on the way back. Switching the ignition off and then on cures it for a bit, but then it comes back.
    Today, I drove the car and it only happened twice in the 20 miles I drove. I checked on line and people are saying that it could be a faulty MAP sensor. Where is this sensor and is this the most probable cause.
    It seems like it goes wrong more when the outside air temperature is cold.
    Any help is much appreciated.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    boost sensor is on the top part of the inlet manifold , at the engine side & is held in with 1 torx bolt .
    my vectra dti did the same thing when I first bought it & limited itself to 3000 rpm , cleaned the boost sensor & wiring plug , all ok after that .
    Jan 2012
    Cornwall
    Thanks, I'll give it a go tomorrow.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    p0105 & p1105 are related to your barometric pressure sensor , this sits behind your maf in the engine bay. first thing to do is to clean and check the elec connections between the sensor and the maf , at the same time remove the sensor and clean the sensor port with carburretor cleaner , this may be all thats needed but these sensors do fail eventually
    and still loving it
    Engine : 2.0DTi
    Mileage : 73350
    P0105 & p1105 are related to your barometric pressure sensor ,
    p0105 is your ecu telling you it has detected a fault with the sensor
    p1105 is your alternator saying it has detected a high value fault which usually means a open circuit or a short
    First thing give the sensor port a clean with some carburrretor cleaner by removing it the port is at the bottom
    Next give the elec connections a clean with some emery paper or wire wool .
    Replace and see what happens it may solve it but failing that then its probably a new sensor thats required .
    around ú50 from a stealer around half that from online retailers
    and still loving it
    Jan 2012
    Cornwall
    Havn't got round to looking at the MAP sensor, had to finish my extension, give birth to my first child (well, the misses did) and general other stuff. But I have found if the outside air temp is above 10 degrees, the fault very rarely occurs. I've got a space 5 minutes tomorrow, so I'll take the sensor out and clean it. Then I'll wait for a cold day, should be one soon, and see if the problem is solved
    Engine : 2.0DTi
    Mileage : 73350
    I dont think the fault is temperature induced , mine failed during the summer last year so i doubt it could be induced just by cold weather.
    and still loving it
    Jan 2012
    Cornwall
    Yeah. I still havn't had time to take a look at it yet as it's only done it once in the last week and it's been down to 2.5C outside without the fault.
    Jan 2012
    Cornwall
    Still havn't looked at this problem as it hadn't happened for a week or so, then today it threw up the light on the right hand side of the dash, Exhaust Emmisions. When scanning the fault was P0105 and P1105 again. I pressed erase and the light went out.
    Why would that light come up on the dash and not the usual car/spanner light?
    Jan 2012
    Cornwall
    Haven't posted in a while as I had to get a new battery about a month ago, and since then, the fault hasn't re-occurred!
    I did notice that the fault happened mostly when idling or when the engine was under a lot of load, so maybe the old battery was bringing the voltage down a bit and therefore getting incorrect signals back from the MAP sensor.
    Anyway, it seems OK now.....Time will tell
  1. HELP PLEASE - Trouble codes: P1105-FA and P0105-FA
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 27th November 2015, 14:37
  2. PLEASE HELP!! Error codes p1105 & p0105
    By signum_05 in forum Troubleshooting
    Last Post: 23rd December 2012, 10:16
  3. Error codes p1105 and p0105
    By signum_05 in forum Engine & Drivetrain
    Last Post: 3rd July 2012, 12:58
  4. 2 fault codes p0105 p1105 can any1 help??
    By barrymanalow87 in forum Engine & Drivetrain
    Last Post: 23rd September 2009, 09:08
  5. P1105 and P0105 Help?
    By vectra2004 in forum Troubleshooting
    Last Post: 30th July 2008, 00:30
zafira dti p0105
opel signum b┼é─ůd p1105
vectra c p0105 atsiliepimai
vectra c 2.0dti air mass meter faults www.vectra-c.com
Opel P0105
p1105 zafira
map sensor vectra c 2.0dti
p1105 vectra dti
vauxhall vectra 2005 p1105
zafira 2.0 dti map sensor location
Where is the map sensor on vectra c 2.0 dti
opel signum p0105
p1105 astra 2.0dti
p0105 opel vectra c
P0105 2.0 vectra
vectra c barometric pressure sensor
p1105 zafira a 2.0 dti
p0105 signum
Vauxhall signum p1105
zafira 2.0dti p0105 p1105
dti p0105
fault code p1105 astra dti
p1105 2.0 dti
vauxhall 2.0 dti p0105
p1105 vauxhall
