Thread: vectra dti
    Jan 2010
    norfolk
    Default vectra dti
    hi can someone tell me which way to adjust actuator rod on turbo on my vectra 2.0 dti on 2003 plate and does it make any difference thanks
    Dec 2011
    Somerset
    I would say not to touch it. If you have over boost problem then you need to find out why. Adjusting rod length is just going to mask the problem and reduce how often it happens. If you still want to then two turn to make it longer. But more than likely either the vacuum solenoid is faulty or the reservoir vacuum solenoid is playing up. I had problems with both on mine!
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Worth checking for a P0234 code before you do the solenoid adjustment in the link above. Definately worth checking all the vacuum tubes and boost hoses.
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
