Thread: Info Display (??)
    Dec 2012
    Benfleet
    Engine : 1.9CDTi 150
    Default Info Display (??)
    Hi all after some help here, owned my early 2005 (pre Facelift) Signum 1.9CDTi 150 for a couple of days before i noticed that the info display (inside the rev counter) appears to be faulty. all i get is a faint orange or red glow. e.g. if a door is open it glows red, and glows orange for about 4 minutes after starting (after a bit of searching on here i think this is due to faulty glow plugs).
    Anyway, can anybody help??
    Chris
    Dec 2012
    Benfleet
    Taken the instrument cluster apart and found the reason for the info display not working!!
    the previous owner had used a knife to hack the ribbon cable that runs to this display, and also stuffed paper into the hole above the LED for the glow plug!
    starting to think that the minor teething problems i'm experiencing with this car are more sinister than that!! think i may have been sold a lemon!!
    Looks like it's time for a new instrument cluster, can anyone advise, do i just need to find one with 0-160mph and 0-6000 rpm, or does it have to come from the same model?? seen some on ebay, but they say they are from a 2.2dti.
    Thanks.
    Admin plasma's Avatar
    On the Forum
    324 Post(s)
    Engine : 150
    Mileage : 74000
    if u get one with the same rev range and mph you'll be ok, but try to get one with roughly the same mileage as yours as it will cost about £100 to get them changed to the correct mileage. Also make sure you get the security code for it incase you need to change one of the settings like for AFL, IDS+ etc etc.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    milton keynes
    What mileage has the car done? I have a few sets of clocks here. Lol.
    Dec 2012
    Benfleet
    Thanks guys, she's done 110,000 miles.
    milton keynes
    I have a set of facelift clocks with roughly that mileage on , but they have had a LED conversion. The facelift clocks differ as they do noy have that small window on the left and some of the symbols are in different places , on a plus side they illuminate when the ignition is switched on , the prefacelift clocks do not do this.
    Dec 2012
    Benfleet
    Couple of ququestions are they a straight swap?? What colour LED conversion?
    cheers
    On the Forum
    324 Post(s)
    Engine : 150
    Mileage : 74000
    they will fit right in, i tried a facelift set in my preface when i had an airbag light problem without any issues, as stated they are different with different symbols in different places, depends if you want to keep to 'factory' style or go for modding lol, the most common conversion people do on here are blue, so imagine if kman had any to GIVE you it would be blue.
    milton keynes
    I will need to double check , but 99% sure that the set around that mileage was done in white, the can be converted back to orange too.
    Dec 2012
    Benfleet
    Already decided on a blue conversion.
    as long as I know that any cluster with the correct MPH &RPM range will fit I'll look on eBay. Think there's a couple with similar mileage. I can even carry out the led conversion before fitting then!!
  1. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  2. Info' display
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2008, 17:53
  3. Info display / computer
    By david.aka.judas in forum Electrical & ICE (including SatNav)
    Last Post: 24th April 2007, 20:14
  4. Computer? info display
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2007, 09:14
