Thread: passenger window switch
    Oct 2012
    wrexham
    Default passenger window switch
    so my passenger window switch works but dosnt work ha. it lets the window down but wont bring it back up faulty switch you reckon how easy are they to swop??
    Regular Member Phil881's Avatar
    Sep 2012
    Edinburgh
    It's a common fault.
    Mine did the same, try taking it out, taking it apart and cleaning the contacs. Worked for me
    Regular Member Blurry120's Avatar
    Mar 2012
    Tameside
    6 Post(s)
    Trim : SRI, now with half leather!!
    Engine : 1.8 16v ZXE18
    Mileage : 106,000!
    what he said, works a treat, plus saves cash spent too
    Nov 2015
    Trim : Sri
    Engine : 1.8 petrol
    Word of warning did this fix today however tried a shortcut and dropped the switch and surround into a tub of contact cleaner rather than just removing and stripping down the switch itself . This resulted in the paint on the surround peeling off and jamming the switch up . You really need to prise the switch from the surround and fully strip it . Be careful not to loose the 2 white plastic slider pegs and it's important that the silicone membrane is put back in correctly or its rocker motion won't be correct . Glad I did it I now have a functional although not so pretty looking surround ! Replacement switches are available on eBay from about £12 .
    Regular Member Ed307's Avatar
    Apr 2015
    Dublin, Ireland
    Vehicle : Vauxhall Vectra
    Trim : Exclusiv
    Engine : Diesel
    A quick wipe with a dry cloth was all mine needed - not even contact cleaner or sandpaper
  1. Passenger Window Switch
    By Carl83 in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2013, 17:23
  2. passenger window switch
    By Keithy in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2010, 22:22
