Thread: Broken cam chain guide
    Dec 2012
    Birmingham
    Default Broken cam chain guide
    i have a vectra c 2.2 elegance (z22se i think) i have only owned for about 2 months.
    about two weeks ago i started the engine and suddenly heard a constant tapping noise. the next day it got much more worse all of a sudden and the car cut out and wouldn't start. i think it killed the battery.
    i got it towed home and took the timing chain and cylinder head off. the black chain guide came out in two pieces but i'm sure there is more of it missing. the pistons look like they have nicked the inlet valves and the inlet valves don't seem to sit in the head flush.
    will i need to change inlet valves?
    i was gonna change head gasket as well as a new cam chain kit and balance chain kit
    cheers Froggy
    Regular Member Paulwr's Avatar
    Mar 2012
    Ormskirk, Lancs
    Vehicle : Astra H 1.8 VVT
    Trim : SRi XP 3dr
    Engine : Z18XER
    Mileage : 12k
    Hi mate.
    I recommend you visit http://www.z22se.co.uk/forum/portal/ for some advice on this engine. There are some really knowledgeable guys over there.
    Edit: Plus they have a site shop selling genuine chain kits and spares at great prices.
    Aug 2011
    Bristol
    Use the above.
    Great guy and can get all the kit direct.
    Exactly the same for mine 3 months back and I had all valves changed (few seemed bent). Head needs skimming and testing.
    Whilst there we also did the piston rings as 2 and 3 were leaking oil. This meant we had to check the sump tray for my missing piece of plastic which never turned up again.
    New timing kits put on, gasket's will be needed.
    Due to the location of the car it was deemed as very difficult to change the water pump.
    Now it's back together I have coolant leak which I believe is the water pump. More cost to change so get it changed whilst there as well.
    I wish I had not started this now as I am down 2 grand (other issues as well) and more needed for pump/issues.
    Scrap it if you don't have funds unless you know a good guy that will do all at once.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by Froggy View Post
    cheers Froggy
    This might help visualize, as for the valves if they have hit they will need replacing.
  1. pesky upper timing chain guide bolts‏
    By Noeli0 in forum Engine & Drivetrain
    Last Post: 24th October 2012, 07:32
  2. Vectra VXR - Primary & Secondary Chain replacement Guide
    By peelmeister in forum Engine & Drivetrain
    Last Post: 31st July 2012, 12:50
  3. Broken banks of river = broken vectra...
    By andrew e in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 20:48
  4. Inner Tie Rod Guide
    By aruffell in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2011, 21:42
  5. sky hd tv guide
    By solorider in forum The 'Off Topic' room
    Last Post: 12th May 2010, 12:43
