Thread: Help Steering Rack Universal Joint....
    Oct 2007
    Shropshire
    Default Help Steering Rack Universal Joint....
    HI
    I have play in the universal joint that connects the steering columm to the rack. I have tried a few searches and cannot seem to find much, mostly about the rack itself.
    How much is this part and how hard is it too replace. Anyone know any part numbers???
    I have changed the track rods, and am pretty sure it is the joint and not the rack.
    Regular Member ScottyV6's Avatar
    Feb 2011
    Worcester
    Just thought I would post on this one, My findings in reference to the steering column UV joint.
    Apparently there is a bolt or 2 which can come slightly loose, and other members on here have had a lot of joy by nipping up the said bolt. The reason it came up today as my mechanic had told me my UV joint on steering was what was causing my steering to knock when static. I told him about reading on here, that it is possible for bolt to come loose.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try nipping it up first
    VIP-Member paulmac's Avatar
    Slough
    9 Post(s)
    Definitely try the pinch bolt as they do work loose.
    If your rack does need replacing it's not too difficult, I changed mine a couple of weeks ago.
    Oct 2007
    Shropshire
    Thanks for the replies guys, I have been away so sorry for the delay in response, I do appreciate your help. I have already done the pinch bolts a couple of years ago (The one under the bonnet and under the dash), which did fix it, but now it is definitely the UJ itself. If you put you hand on the uj and get someone to rock the steering wheel back and forth you can feel the play. The top part moves more than the lower part!
    It just passed the MOT so not too bad, but definately can feel it so will leave it until it starts to get a bit warmer and tackle it then!
    Will try and source a lower column in the meantime. Any one got any ideas of where or a part number?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Just try tightening it again for time being you may find it improved it until later on for Warmer weather
    Mar 2016
    Poulton Le Fylde
    Vehicle : vectra 1.9cdti
    Trim : club
    Engine : 1.9
    Merry Christmas everyone
    Just come across this thread and i am asking the original question asked by Mucklestone... How easy is it to change the steering Universal Joint?
    mine has play in the joint on the engine bay side, it is obvious to the eye and before anyone suggests it... the pinch bolts are tight. I've looked for a How 2 but can't see one.
    I've found the part just need to know how to do it
    So any of you good people any tips on how to change it
  1. mot advisory offside inner steering rack joint has slight play
    By wiganrl in forum Vectra C / Signum Troubleshooting
    Last Post: 5th May 2011, 12:29
  2. steering rack
    By gsi3.2Daveyg in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2010, 20:54
  3. Steering rack
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2010, 01:50
  4. steering rack?
    By the_wave_rider in forum Suspension, Wheels & Brakes
    Last Post: 27th December 2009, 13:52
  5. Steering Rack
    By maxd cavy in forum Engine & Drivetrain
    Last Post: 26th June 2009, 09:21
vectra c steering column joint
vauxhall combo steering universal joint
vectra c universal joint
vauxhall vectra c uv joint
vauxhall vectra c universal joint
tightening universal joint on vauxhall combo
vectra c steering universal joint
vectra c steering rack
vauxhall combo steering universal joint diy
can opel corsa steering u-joint be replaced
how to change uj joints vectra c steering
vauxhall vectra steering universal joints
vectra c steering rack inner joint
vectra c steering uj
vectra c pinch bolt
2007 vectra univesal steering joint part
how do i change vectra steering universal joint
uj part vauxhall vectra
vectra c uj steering
how much to replace a corsa steering universal joint
vauxhall corsa uj replacement
how to change corsa 2005 steerwheel universal joint
how to fix vauxhall corsa c steering universal joint
easy way to remove universal joint on vauxhall vectra
can i buy a universal steering joint for a 2007 vectra
