Thread: LED Strobing & Resistor Size?
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Default LED Strobing & Resistor Size?
    Has anyone got the definitive answer for this? what size to use to fool the pulse etc...
    Been thinking of doing a couple of relays so i can fit LED reverse and brake bulbs, but I'm not going to wire in a loose bulb holder like on my fronts... Bit too messy IMO...
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    I've got a circuit on test at the moment mate on my Cree LED Full beams. It's a little more complex than just a resistor though. There's transistors, caps and diodes in there too. It's just a case of trimming the cap value up enough to absorb the pulse but not stop the transistor from working.
    21 Post(s)
    Mileage : 110k
    Bulb holder it is then... pmsl
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    It wont stop the strobe, only the bulb error message.
    21 Post(s)
    Mileage : 110k
    I'd planned to put a bulb holder before the block (for warning) then this onto trigger a relay, take a 12v for the relay to the bulb tray... should be fine. just didn't want loose lit bulbs like the front side lights...
  1. strobing led's
    By patch22 in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2017, 22:44
  2. Will this stop my 501's strobing?
    By coldo in forum Electrical & ICE (including SatNav)
    Last Post: 15th May 2013, 08:35
  3. Strobing LED's
    By rmg1 in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2012, 21:10
  4. What size resistor?
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2012, 11:51
  5. stopping strobing idea
    By mrk in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2012, 12:16
