Results 1 to 10 of 24
Thread: Strobing LED's
    Regular Member rmg1's Avatar
    Limavady, N.I
    Vehicle : Vectra C Sri V6 CDTi
    Engine : 3.0 V6 CDTi Z30DT
    Mileage : 121000
    Default Strobing LED's
    I have fitted LED sidelight and number plate bulbs but they strobe when the car is running and for about 30secs after you lock it, is there anyway to stop the strobing?
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    My sidelights do it with the lights off (fine when they are on) but not my number plate ones. I think it's quite cool
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    There would be a long winded or relay wiring answer, but it doesnt cause that much of an issue as shouldn't be visible during the day, at night you'll have your lights on...
    This reminds me, i need to right a resistor thread lol...
    11 Post(s)
    Quote Originally Posted by rmg1 View Post
    Fit 501 filament bulbs instead
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    I fitted LEDs to mine also yesterday and as said fine while driving with lights on but I have a feeling they could attract the attention of the police as when the lights are off they flash alternately with a blue tinge. I'll probably have to swap them over with the wife's car
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    i thought if you got canbus friendly with buily in resistors you were fine?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    All the resistors do is put a load on the system replicating the load a bulb would put on it so that the bulb check system thinks there's a bulb there and doesn't trigger a warning on the dash.
    The strobing is caused by the low voltage pulse used by the bulb check system to check the bulbs, it's not enough to make a normal bulb light, but LED's run at a much lower voltage and respond quicker so they flash or strobe as a result of this pulse. As yet there's no way to defeat that apart from running new circuits in and running the bulbs on those.
    It's never bothered me, the only ones I have LEDs in are my Angel Eye halos and I drive with side lights on all the time so they're lit anyway.
    Sep 2012
    Engine : 3.2
    Cool - was pondering LEDs myself for exterior lights but I'll not bother now I think.
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    just a thought -using the origional live to switch the relay and battery live to run the leds does bulb check voltage not knacker the relay prematurely? thinking bulbcheck may constantly switch it on and off.
    23 Post(s)
    Mileage : 110k
    Stops the strobing but you'd get the warning, you'd still need a bulb tucked away before the relay or a resistor... I just put new 501 holders wired from the dash illumination, tucked the old ones away.
  1. strobing led's
    By patch22 in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2017, 22:44
  2. Will this stop my 501's strobing?
    By coldo in forum Electrical & ICE (including SatNav)
    Last Post: 15th May 2013, 08:35
  3. stopping strobing idea
    By mrk in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2012, 12:16
  4. strobing interior lights
    By farley2708 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2011, 20:31
  5. eeerrrmm help strobing hids
    By Morephun in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2009, 15:32
