Results 1 to 10 of 11
Thread: Servo pushing oil through turbo
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Default Servo pushing oil through turbo
    Hi all,
    Got a bit of an oil problem. lately ive noticed im getting blue smoke through the exhaust. So, I took of the inlet pipe and found oil inside it and also in the turbo inlet. I checked all the pipes i could and found all where dry apart from the T junction coming out the vacum. I cleaned it up but it keeps coming back. Today whilst driving home, i noticed a lot of smoke when i braked to a stop. Could it be something in the vacum leaking oil into the breather, then when I brake, it gets pushed down a breather (pressure from the servo pipe to T junction vacum pipe) and then into one of the 2 small breathers on the inlet pipe. My guess is a fault in the vacum????
    The has been gradually been getting worse
    Also, after driving for an hour or so when the engine gets warmed up, the car seems to loose all the power when setting off from a standstill. it takes alot of clutch work to get going. Ive just replaced both boost sensors but not had chance for this to see if this the problem. Maybe this could be related the above problem??
    Any help would be greatfully appreciated
    Regards
    Jim
    Jan 2012
    Gloucestershire
    Firstly, I'm not a mechanic, so my experience is limited to the 1.9cdti mostly as I've had more than my fair share of trouble with them. So excuse any flawed ideas below, but thought I would give you a few ideas to go on...
    Not sure what engine you have, but oil into/around the turbo inlet could be faulty turbo seals allowing oil into the intake system. May not explain the oil in your vacuum line though.
    On the 1.9cdti engine - not sure about others - the vacuum pump is situated on the end of the cam shaft and if the seals from this leak then you could end up with oil in your vacuum pipes.
    Lastly, are you sure that you don't have a breather pipe from the camshaft cover back into the air intake just prior to the turbo? This could be a sign of high pressure in the cam casing forcing oil back through the breather. A compression/leak test may help diagnose this sort of problem if there is a leak from the cylinders (piston rings, valves etc...).
    Hopefully someone with a bit more experience can help more. Good luck!
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Engine is z20net
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Take a couple of vacuum pipes completely off and blow through them. If you get oil dripping out then it sounds like a knackered vacuum pump. From your profile it says you have an edition 100 which will be the 2.0 turbo. Only know where the vacuum pump is on the 1.9 CDTi so can't help you with a location.
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Ive checked all the hoses and the only oil i found was at the vacum connection. all other pipes were dry and clear.
    Ive been reading a few other threads and found that the vacum o ring can perish, which coincidentally the vacum was removed recently when the cam chain was replaced.
    Tomorow ill strip it down to check the vacum and o ring.
    Anyone got a part number for the o ring?
    Regards
    Jim
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Does the vac pump have any other o ring apart from the one in the pic?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Quote Originally Posted by cont1204 View Post
    Wheres this vac pump? I like to learn as i go! :-)
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Jan 2012
    Gloucestershire
    Again, I don't know anything about your engine or vacuum pump, but the large shaped seal must only be for leakage to the outside world - i.e. won't leak into you vacuum pipes. I would have thought that there must be internal seals that perish.
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Ive removed, stripped and cleaned the vac pump. inside theres no seals, the oil should flow back through a hole into the engine. Hopefully claning it out may have unblocked the hole and the oil will not be forced through the breather. ill give it a week or so to see how it goes. If it carries on ill replace the vac pump.
    Thanks for your input
    Jim
  1. changing discs and pads, pushing pistons back.....
    By taffy bhoy in forum Suspension, Wheels & Brakes
    Last Post: 9th October 2012, 22:33
  2. Clicking sound when pushing on clutch
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 12th April 2011, 22:25
  3. C/C air servo question
    By Big Sig in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2009, 14:22
  4. Clunk when pushing the rear wheel
    By richpu in forum Suspension, Wheels & Brakes
    Last Post: 10th May 2007, 08:25
turbo oil in servo
