Results 1 to 10 of 20
Thread: power problem with my vectra 1.8 sri vvt help???????
    Nov 2012
    Redcar
    Default power problem with my vectra 1.8 sri vvt help???????
    hi i bort a vectra 1.8vvt sri petrol 50k on the clock from drive vauxhall abowt a month and half ago,nothing but problems,had new drop link bar,camb belt,alternator + battery as power steering kept going off, now it keeps hessertating to go and the engine light has come on help anyone on what it could be coz drive dont seem to have a clue thanks
    Regular Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    sounds like the problem mine had try the cam shaft solenoid filter removal trick see if that work for you just seach cam shaft solenoid and you will find how to do it
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Had very similar problems. Turned out yo be a faulty coilpack. Got a second hand unit for 60 quid and its been fine since.
    If you near to me i could hook up the laptop to see what errors you may have.
    Common problem on the 1.8 vvt btw
    Nov 2012
    Redcar
    thanks mate il tell drive vauxhall as they seem not to have a clue,its under warrenty so they can fix it as its been an ongoing problem, what do you think of the vectra 1.8vvt sri? any good or unreliable??
    Dec 2011
    Seaham
    They need to read the codes to diagnose the problems. The VVTi is a good engine, has less problems then the popular diesels.
    Without reading the codes it is hard to diagnose the problems. A duff plug or coil can cause misfiring. They have cam phaser solenoids to activate the VVTi, these can stop working properly and will throw up the engine management light and put the car into limp mode. Thankfully the solenoids are a doddle to change.
    Nov 2012
    Redcar
    ok nice1 mate il let them know. iv had nothing but bother with it since i got it just over 1 month ago,alternator+battery 2 days ago. will it be safe to drive local?
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    As long as the eml is not flashing you will be okay.
    Im amazed the garage does not know what it is.
    As said above you need to have the codes read.
    I would guess you may have a cylinder missfire
    Oct 2007
    Shropshire
    I think you just need some reassurance! Just try not to get disheartened. A cambelt is a consumable most cars have them and they all need changing when they get to the interval and this time of year a battery is a common thing on any car that is more than a couple of years old..... Equally I beleive it is a boosh alternator on it and they again they can go on any car, especially if the battery has been a bit duff for a while!
    Check the coil pack. Common problem on many modern cars if the plugs are not regapped or changed.. The spark plugs should be changed every 30k I believe, yet most people nowadays never do them.... Look through the service history and if you cannot find spark plugs I bet its that.... Otherwise solenoids as antowens said.....
    Really you need to get the codes read otherwise we are all just guessing! Hope you fix it quickly and cheaply.
    Regular Member dave1419's Avatar
    Jun 2012
    newcastle upon tyne
    9 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    I would be telling the garage you bought it off that the car is not fit for purpose and therefore you want and need for it to be repaired to a standard that you will be happy with,if not then tell them you don't want it and get your money back.I bought mine from a Vauxhall dealer in Darlington and they have been spot on with any problems i have had,they also have a dealership in Stockton-which is not far from you and if you find that you have to hand the car back in to the one in Redcar i would be giving this dealer a call to see what they have in stock.You don't have to put up with this type of treatment.I would also stop having a try to fix the car yourself as this may cancel what ever warranty you have. Hope you get sorted out soon-----Dave
    Nov 2012
    Redcar
    thanks every1,got a hire car from them for now,they going to have a look at it on monday,iv paid for a warrenty when i got the car so they can fix it for free as its been an ongoing problem,do u think im just having abit of bad luck or shud i get rid of the car?????? just seems problem after problem since i got it.the garage have been fine abowt fixing it but its been in and out 5-6 times in 1 and a half months,i love the car but just seems i waiting on sumthing to go wrong when i get in it
  1. Help!!!Vectra 05 1.9 SRI CDTI power problem!
    By sohail1989 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2012, 00:32
  2. Vectra 05 1.9 SRI CDTI power problem!
    By sammcc15 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th July 2012, 20:57
  3. Vectra C 52 Plate Power Steering Problem
    By Nath79 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th February 2011, 14:28
  4. Vectra Estate power tailgate problem
    By Snizzers in forum Bodywork & Interior
    Last Post: 3rd June 2009, 23:03
  5. power problem on diesle vectra
    By michael29 in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 17:57
vauxhall vectra 1.8 sri problems
vauxhall vectra 1.8 vvt sri problems
vectra 1.8 problems
vauxhall 1.8 vvt engine problems
vectra 1.8 vvt problems
vauxhall vvt engine faults
pic of vectra vvt 1.8 engine
how are vectra c 07 1.8 Sri engines
vectra c 1.8 common problems
vauxhall vectra 1.8 limp mode
usterki w vectra c 1.8vvt
vectra c 1.8vvt coilpack
vauxhall vectra sri problems
vectra 1.8sri cam solenoid
vectra c 1.8vvt
vauxhall vectra 1.8 sri 2006 problems
vauxhall vectra sri vvt 1.8 coil pack
Vectra C petrol common problem
vauxhall vectra coil pack problem
vvt engine problems
vauxhall vectra forum problems
astra 1.8 vvt common problems
Vectra c oil problem and down on power
breathing problems vectra c vvt 1.8 vvti
vectra c sri
