Results 1 to 10 of 13
Thread: 3.2 cylinders where?
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    Default 3.2 cylinders where?
    BAH! Got a misfire and engine check light, used the pedal method to get the codes - 0305 and 0306, so misfire on cylinders 5 and 6.
    Can anyone tell me which these are, the rear bank or the front. Also if I get a new coil pack are they the same for front and back banks?
    Cheers...
    Dec 2011
    Seaham
    I would have said that 5 and 6 would be the rear two cylinders, the ones furthest away from the front pulleys.
    Sep 2012
    Engine : 3.2
    *******. I think 5 is rear and 6 is front, that sucks.
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    20 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 220,240
    I hope it is the coil packs. My old Omega V6 went bad on me: misfires on two or more cylinders. I replaced spark plugs... HT leads (it was an X30XE)... then tappets... No change. It was down on compression on those cylinders, so had probably suffered valve seat failure, broken valves or something that was affecting cylinder sealing. I hope you have better luck! How many miles has the car done? Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Sep 2012
    Engine : 3.2
    It's only done 78k and before the check light was pulling fine and sounding fine so fingers crossed.
    20 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 220,240
    Probably something straightforward then. :-D My Omega had 172,000 miles on it when I gave up! And my GSi has 143,000+ too. Hopefully it still has some life left in it. I'm trying to think how you could diagnose the problem. It's a pity it's not easier to borrow coil packs... Paul
    Sep 2012
    Engine : 3.2
    yeah it's coil packs, both banks. arse etc.
    20 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 220,240
    Saw one on eBay - 99p start price. Worth a punt?
    Paul
    Newcastle, Australia
    http://www.vauxallparts.co.uk/vauxha...312-763403.php
    How to change coil on Vectra C 3.2 Gsi
    Not too hard... Literally take off the plennum (top silver part of the engine with the 3 round banks on either side of it) by pulling off the black plastic stip on top and you'll see 5 holes, inside each one is a torx screw, can't remember the size... possibly T30? Shine a torch down and check. Uscrew them, the plennem should wobble a bit now. Disconnect most things except the fuel line, push it out of the way. There's one more torx screw under the throttle body, you need to remove that (three torx screws, two on top and one under the opening). Get that off and just hold it away and you'll see the same size torx screw as the plennum screws holding the plennum on. Unscrew and the plennum will lift... Underneath you'll see inlet manifold and the coils on either side, you may need someone to hold up the plennum while you unscrew and pull off the coils. Change them etc, prob best to do plugs while you're there unless they're reasonably new. Put everything back and off you go :-)
    Sep 2012
    Engine : 3.2
    Aye, cheers. Trouble is I can't get the parts til during the week and then I'd have to wait til the weekend to do it for the light. VX can get the parts for tuesday and do it for wednesday morning and the work is all warrantied so although it's pricey I'm going to let them do it.
    I really hope this is the last big thing for a while.
  1. running on three and thre quarter cylinders
    By phieziem in forum Engine & Drivetrain
    Last Post: 28th March 2014, 22:38
  2. Misfire on cylinders 1&4, help please!
    By petevectra in forum Engine & Drivetrain
    Last Post: 20th July 2012, 18:58
  3. Only running 3 cylinders !
    By Stan-H- in forum Engine & Drivetrain
    Last Post: 20th February 2012, 23:39
  4. Help! Misfire on cylinders 3 & 4
    By deales82 in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2011, 20:57
  5. Been to VX to sort out why my car is running on 5 cylinders
    Last Post: 23rd September 2007, 10:30
