Thread: diesel return to pump on stand still?
    Oct 2012
    Leicester
    Default diesel return to pump on stand still?
    hi guys
    am having a few problems with starting up ive had a machanic out and he start there was a air lock and the the diesel is returning to pump so when i try and start the car theres no fuel getting to the rail
    hes sorted it and it started fine took it for a spin everything ok
    untill this morning now the same thing has happened
    does any1 know why this keeps happening ???
    Dec 2011
    Seaham
    Sounds like you have a very small leak?? Which is allowing the fuel to drain back.
    Oct 2012
    Leicester
    where would the leak be?? any ideas?
    Dec 2011
    Seaham
    Can you see any diesel that has leaked out? Around the injectors, fuel pump etc? If diesel leaks out, then air will leak in. Other then that, is there a non-return valve that has stopped working. Sorry, not a diesel man myself.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Leak off pipes on the injectors? Could the mechanic not at least try and locate this for you?
    Oct 2012
    Leicester
    are the leak off pipes expensive to replace once ive found the leak that is?
    the mechanic is coming tomorrow morning to see he can get it started i just wanna no how much am looking at before he charges me a fortune to get replaced
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    No more than £20 for the pipework. Should take around 30 mins to fit diy
    Oct 2012
    Leicester
    any1 got any pics so that i can see which pipe it mite be?
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Am I correct in guessing its a DTI (It doesnt say in your profile)?
    Oct 2012
    Leicester
    yes mate dti
  1. Diesel pump
    By ads3 in forum Engine & Drivetrain
    Last Post: 9th June 2011, 18:57
  2. Diesel pump???
    By pasty steve in forum Engine & Drivetrain
    Last Post: 15th September 2010, 15:34
  3. Diesel Pump?
    By jrpatten in forum Engine & Drivetrain
    Last Post: 14th February 2009, 21:47
  4. Need me a diesel pump!!!
    By cov in forum Engine & Drivetrain
    Last Post: 20th January 2009, 18:42
  5. diesel pump!
    By littlesxi in forum Diesel Engine related
    Last Post: 29th January 2008, 01:15
