Thread: Smoke from engine
    May 2012
    UK
    Trim : SRI
    Engine : 150 CDTI
    Mileage : 124000
    Default Smoke from engine
    Hi all
    Hoping for some help if poss...
    I have a 150 CDTI (facelift) with 110k.
    Over the last couple of days i have noticed smoke (not loads & intermittent) appearing in headlight beam (mainly drivers side) which is coming from the engine.
    Overall the car runs fine, mpg is good, smokes from the exhaust if planted and a puff from a cold start which what i gather is pretty normal. It is due a service/mot, and this is booked in on xmas eve!
    Any ideas on what it could be?
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Could be your waterpump about to seize and damage the timing belt, Get it checked asap
    May 2012
    UK
    Trim : SRI
    Engine : 150 CDTI
    Mileage : 124000
    ****** - i hope not sounds expensive It warms up ok and heat comes through the vents as normal!
    Regular Member Dai69's Avatar
    Nr Welshpool
    Vehicle : Vec C Estate X 2
    Engine : CDTi 150
    Year : 55&56
    Mileage : MANY
    Slight oil leak onto something hot? Or a bearing seizing/belt breaking up? Brake pads dragging? Cluth slipping?
    What does the smoke smell like? Oil, rubber, brakes/clutch?
    May 2012
    UK
    Trim : SRI
    Engine : 150 CDTI
    Mileage : 124000
    Quote Originally Posted by Dai69 View Post
    Not managed to get a whiff yet, doubt its the clutch although its abit noisy at biting point doesnt slip at all, could be anything youve mentioned - not knowing is the most frustrating thing!
    Ive managed to book in with a local mechanic at 2pm today - will report the findings, fingers crossed its something and nothing
    Nr Welshpool
    Engine : CDTi 150
    Year : 55&56
    Mileage : MANY
    Quote Originally Posted by elite_150 View Post
    Hope it's nothing serious or expensive. Fingers crossed for you
    May 2012
    UK
    Trim : SRI
    Engine : 150 CDTI
    Mileage : 124000
    Thanks buddy
    Just got back from the garage - fuel filters leaking a fair bit - theyll tighten it up and re-seal and i'll pick it up later this afternoon, they will charge 1hrs labour@ £30 - hopefully this is whats causing the smoke!
    Jul 2011
    UK
    Year : 06
    Thanks buddy
    Would it not be best to change the filter
    May 2012
    UK
    Trim : SRI
    Engine : 150 CDTI
    Mileage : 124000
    Quote Originally Posted by marc vectra sri View Post
    Maybe - how much would it normally cost to replace and fit?
    Oct 2010
    London
    Same as labour + about £10 for the filter mate! For them to tighten the filter up they should take it out of the crash box etc, so for 2 minutes extra they can swap the filter!
    Worth doing then doesn't need to be thought of for a couple of years.
  1. Help smoke from engine
    By Sway in forum Engine & Drivetrain
    Last Post: 27th January 2013, 18:46
  2. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  3. Smoke in my engine bay - oh no!
    By steve533 in forum Engine & Drivetrain
    Last Post: 15th January 2012, 14:48
  4. Smoke From My Engine
    By Keith01 in forum Engine & Drivetrain
    Last Post: 10th March 2011, 23:01
  5. smoke and engine judder/lag
    By phiniasfreak in forum Engine & Drivetrain
    Last Post: 27th April 2009, 13:33
