Thread: Air con
    Regular Member richy1974's Avatar
    Jun 2012
    leek
    Default Air con
    Need a bit of info please been using my aircon to demist the windows.
    Now should the cooling fans kick in as soon as you turn the a/c or not .
    On my seat the little fan kicked in soon as you pushed the a/c button is it same with the vec.
    Regular Member yessof's Avatar
    Jan 2008
    west yorkshire
    Not sure of the exact temperature, but the air con will not work below a certain temperature.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The cold protection temperature for the aircon is typically 4-5c... below that the aircon is disabled.
    Darlington
    unlike my Astra G, the aircon compresser will also not kick in - if you do not have a fan speed selected ( I have found that you also have to have a fan speed selected even if you use the quick demist button, to get it to work with the aircon)
    My Astra G would switch on the fan at speed 1 if you pressed the aircon button and there was no fan speed seleted.
    Jun 2012
    leek
    Quote Originally Posted by Redviper View Post
    Think you are a bit confused mate not the fan speed but the cooling fans inside the engine bay
    On my old seat cupra when i turned on the air con the smaller of the 2 fans would start to spin. But if i think if it was lower than 3 degrees then it would not come on.
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    On my 07 Design, yes - as soon as you turn air con on the fan ( there's only one on mine ) starts. When it didn't it was the fan control unit that was at fault - follow the wire from the fan motor back. The box you come to should be the control unit.
    Jun 2012
    leek
    Quote Originally Posted by JagRigger View Post
    Mine is twin fans i quite sure the little one should spin soon as you turn the aircon on might have it checked out.
