Results 1 to 10 of 19
Thread: Light Crunching noise when pulling away
    Sep 2012
    Question Light Crunching noise when pulling away
    Hi all,
    Need your help again. I have just got all my discs and pads replaced along with the front right wheel bearing.
    Everything seems to be fine apart from one annoying thing:
    Light crunching noise from front right when pulling away. This only happens when pulling away from a complete stop each time. As soon as you press the accelerator to get moving, there is a little crunch as if something is getting stretched when under tension. There is no such noise when the car is in motion or at any other time and it all seems smooth otherwise. Pretty certain this noise wasn't there before the current work.
    Have already taken the car back to the garage once, they have checked and cannot find anything obvious wrong or missing. They have told me to drive it for a while and see if the noise goes away but I am not convinced.
    Has the garage screwed up something while fitting front right discs/pads and wheel bearing? Have they not fitted something back properly that can cause this?
    Any help would be highly appreciated as I really want to get things perfect after spending a lot on the car recently.
    Dec 2011
    Seaham
    Sre the discs rusting up and you can hear the rust being cleared off?
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Could be the abs?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Sounds like you have a caliper that is stiff and binding on until you move off again
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    Yes sounds like brake pad is binding to the disc - caliper binding. You sometimes get this noise when a car has been parked up for a few days and pads have stuck to the disk with rust but then it's both sides. Try releasing the hand brake before you start, and push the car to see if the brake is stuck on (or if you are on a slope, it should just roll).
    Sep 2012
    Thanks for the replies guys.
    I don't think it will be the disc rust that is cleared off as I move because it started happening as soon as I picked the car from the garage after the work (so no chance of rust appearing that soon).
    ABS - well it may be as it has just got a new wheel bearing hub. Would it cause such a crunching grinding noise each time when you pull off?
    Regarding caliper binding - its interesting you mention this as I have noticed I also have a slight screech when coming to a complete stop and when just taking off. This doesn't happen all the time though. I put this down to new discs and pads settling down and also the rust being cleared after few hours of parking in the rain. Is this assumption correct? The car (being an automatic) does seem to creep forward ok when handbrake is released.
    But the noise I get is strange crunching as if something is getting pulled /stretched the moment I press the accelerator and try to pull off. Note that this doesn't happen when car starts creeping forward slightly (with foot off the brake pedal) but only when accelerator is pressed and you actually try to take off. It only lasts for a couple of seconds like when something is pulled and then doesn't appear till the car is brought to a complete stop and then gets moving again.
    Sep 2012
    Need your expert advice please guys...
    Regular Member biffbangpow's Avatar
    Jul 2012
    ferryhill
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2
    Year : 02
    Mileage : 96k
    strut top bearing , mines just started , similar noise
    Sep 2012
    Will strut top bearing make a noise even when steering is not turned? And will it be specifically on acceleration? My noise has just started coming after the recent work with front right disc/pad and wheel bearing hub replacement, so could they have screwed this up somehow?
    Sep 2012
    Any more suggestions guys? Don't just want to live with the noise as I know something is not right!
  1. Crunching noise on bumps
    By crazychemist76 in forum Suspension, Wheels & Brakes
    Last Post: 26th February 2013, 09:11
  2. crunching noise under braking
    By drspamuk in forum Handling & Braking
    Last Post: 3rd October 2010, 16:50
  3. Crunching Noise when Turning
    By Sean-2.2Direct in forum Suspension, Wheels & Brakes
    Last Post: 15th May 2010, 18:46
  4. Crunching Noise
    By Decker in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2010, 01:31
  5. Crunching noise
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2007, 21:55
