Thread: Z22YH Powerless and studdering!
    Dec 2012
    Sweden
    Default Z22YH Powerless and studdering!
    Hi everyone!
    My name is Sam and writing you from snowy Sweden hoping to get some help with my vectra c Z22YH.
    The problem that has accurd is that it has become powerless until I hit approx 3-3500 rpm and below that at low rpms and slow speeds it hesitates, just as its not getting enough fuel, but the thing is that I have noted that the fuel consumption has gone up quite much...even though it's cold as h*ll here
    I replaced the fuel pump last year as I gave up, went in to limp mode.... And the fuel filter and spark plugs has been replaced this week without any changes as well as inspected the air filter, but I'm running out of ideas and knowledge and really need some help, so any ideas of what the problem could be are more than welcome!
    Thanks in advance!
    Br
    Sam
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I'm not greatly clued up on the 2.2 Direct engine but when you changed the fuel pump, did you do the fuel pressure regulator at the same time? They're a known weak point and from memory, some of your symptoms seem to fit.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yep sounds like the very common fuel pressure reg or the pump
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    had this in my old 2.2 direct and it was the regulator ,,,,, the high pressure fuel pump ,,,,,which make of pump did you fit if it was another seimens one that could be at fault but if it was a continental one i'd go with the regulator
    Dec 2012
    Sweden
    Hi again,
    Well i bought a new regulator, and the problem still remains!
    The fuel pump is a Continental so im hopeing its not the pump again.
    I have also noticed that the engine tempeture has gone up slightly while driving and as the car is running and i shut it off it sounds like the cooling fan is turning of as well, this fan shouldn´t be going due to the outside tempeture here is Sweden at this moment is -6 degress celcius. So could it be that the enging tempeture sensor is failing? Fooling the system to think that engine is cold while its acctualy at the right tempeture?
    Or does anybody else have any suggestions? Im starting too lose hope on finding the issue without exchanging the hole engine!....
    Best regards
    Sam
  1. Z22YH EGR Blanking
    By justathome in forum Engine & Drivetrain
    Last Post: 20th June 2015, 18:38
  2. Z22YH EGR Mod??
    By Stevie76 in forum Engine & Drivetrain
    Last Post: 31st December 2011, 20:06
  3. FPR recall on Z22YH......
    By Nik in forum Engine & Drivetrain
    Last Post: 1st August 2011, 16:40
  4. Z22yh....EGR???
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2010, 12:23
  5. Egr - z22yh
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2009, 12:07
insignia powerless
z22yh additional cooling fan is not working
