Thread: Dti fuel filter
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Default Dti fuel filter
    Hi guy's, I thought I'd post up after doing a few searches, I wondered about posting in the trouble shooting section but its not a problem yet. I was just wondering about people's opinion on changing the filter without the special pump. I bought a new filter today just as a bit of routine maintenance but after reading up about damaging the fuel pump I have been put off changing it as the car is fine at the moment. What's the general thoughts
    Get a vx dealer to do it?
    Or
    Have a go (not keen on this option now)
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Special pump?
    Just take the fuel filter housing lid off, remove filter, put new filter in and top up chamber with some diesel . Then crank like mad until it fires up. Not sure what you mean by special pump?
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    he means a primer. but i used to do the above, remove filter, fit new filter then refil housing with clean diesel, reattach top, pour in more through the bolt hole if u can, then clamp it down, fire it up, it may stall within a few seconds, but turn it over in 10-15sec bursts with 30secs inbetween and it'll fire up fine.
    Sep 2010
    north east uk
    That's the method i use on my Y20DTH. Fill it right up with clean diesel, top back on & it has always fired up as if the fuel system hadn't been disturbed........have never even had the need to crack the injector pipes off.
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Thanks guy's, put's my mind at ease. I'm usually fairly handy with the spanners but a simple filter had me worried lol. The haynes manual puts the wind up you with all that can go wrong inside the pump if run dry.
    Yeah the primer tool i meant is an electric bleeder.
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. Fuel filter help
    By wolvesdaz in forum Engine & Drivetrain
    Last Post: 4th March 2011, 10:47
  3. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  4. fuel filter
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2007, 23:27
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
vauxhall vectra c y20dth fill petrol by mistake
