Thread: Changing Speedo
    Regular Member Vectra_Wilky's Avatar
    West Yorkshire
    Default Changing Speedo
    I've just bought a set of replacement dials off ebay. I still have the standard ones and fancy the nicer SRI ones. Will my mileage appear on the new dials or will I have to change the mileage in some way. If so, how?
    Full Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Your current mileage wont appear on the new dials as they aren't taken from the ecu instead it has its own mileage. Not sure if its possible, but just removing the dial face from the new one and place it in the old casing, it might work.
    If you were to install the new speedo directly, you will have to get the mileage corrected. You will have to take it to a specialist for that. Google ' mileage correction'.
    emec#7
    Regular Member Das's Avatar
    Turdsville
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Just dismantle the needles, the rings and the face off both and swap the sri stuff on to your. I did it with mine, easy job and no mileage worries.
    Regular Member Keif's Avatar
    In the Garage
    I have a similar problem to this.
    Ever since i've had my Signum, the warning display (under the Rev counter) has had a few pixels that have bled. It's slowly got worst, so decided it was time to sort it.
    So, I have a new (to me) set of SRi dials and want to fit them with the correct current mileage. However, if I strip them down and just change the facia, i'll still have the faulty display.
    I've not taken either cluster apart, is there any way I can fit my "mileage" with the replacement good display. Or will it need programming?
    If programming is my only option, I then have the issue that I don't have the Security Code (i've asked the seller if he has it) for the car the clocks came off (and it's saying my security code is incorrect)
    How do I get round it peeps?
  1. Changing speedo with one from ebay
    By Jonsey in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2012, 21:12
  2. gid speedo
    By Al 22 dti in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2011, 17:35
