Thread: Heavy steering when cold
    Dec 2011
    Norway
    Default Heavy steering when cold
    Once again I find myself relying on the great knowledge this forum holds...
    A few days ago the steering suddenly became very heavy. This happended just as the freezing cold norwegian winter set in. It might be a bit heavier to steer to one side. It also seems fine on small movements, it's when doing wider turns it's heavy.
    I checked the steering fluid level, and it seems OK. Hard to tell though, when the container isn't really see-through... I also had a new steering rack fitted early summer, so I'm assuming that's fine, and that the fluid was changed with it. Is this related to the cold weather at all? Could something freeze up/fluid get thicker etc??
    Car is a 2004 Vectra 2,0 DTI estate.
    Any help is appreciated
    May 2012
    UK
    I have the same issue! Mine is definitely heavier, I think it may have started when I stalled and bumped the car when moving. Could it be related?!
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    The steering pump is operated by an electric motor so you need to check the electrical connections - maybe some damp in the connections. The connections may look ok but may not carry the full power needed.
    Dec 2011
    Norway
    Where would this motor - or rather the electrical connections - be located??
    Dec 2011
    Woking
    Trim : Exclusive
    Mileage : 58000
    Just check the main cables around the battery, sorry I'm not an expert. Otherwise see someone who knows.
    The hydrolic pump + motor unit is somewhere behind the engine, under the steering fluid resevoir in my car (2007). earlier cars had it under the wing, behind the wheel arch liner.
    Dec 2011
    Norway
    As the weather is getting a little warmer, the steering is almost back to normal, so I'm assuming this is weather related. Could it be water in the steering fluid? Or could the fluid itself get thick when colder than -10 cel?
  1. very heavy steering
    By GCusdin in forum Suspension, Wheels & Brakes
    Last Post: 4th December 2012, 19:10
  2. heavy power steering
    By datiger79 in forum Suspension, Wheels & Brakes
    Last Post: 14th April 2011, 18:57
  3. Heavy shift when cold
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 7th March 2011, 17:29
  4. Heavy vibration through blower - cold weather
    By leeroberts919 in forum Electrical & ICE (including SatNav)
    Last Post: 17th December 2010, 10:19
  5. Steering heavy HELP !
    By cpt slow in forum Suspension, Wheels & Brakes
    Last Post: 22nd February 2006, 09:03
