Thread: Lowering / bush/links replacement.
    Regular Member Lordish's Avatar
    Feb 2012
    Luton
    Default Lowering / bush/links replacement.
    I have recently purchased some lowering springs and shocks. I will be fitting them after Xmas. At the moment it creaks from both front sides when going over bumps. I'm thinking its the bushes. So when I do the shocks etc i might as well do the bush's and drop links. What do people recommend. Are power flex much better than vx ones. What drop links. Sizes makes etc would be appreciated. I have a signum elite 2.2 direct. Cheers
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    im using just vx bushes, got them to go on, they work fine, you could consider using the upgraded hd drop links, but the hex key makes them a bit of a pain and with the posibility of distorting the head when fitting them, the hd drop links are probably the best thing i have fitted to my vec so far.
    Feb 2012
    Luton
    Many thanks. Ill prob stick with standard bushes as I won't be doing any racing. Sorry to be a bit dumb but what difference to upgraded drop links make.
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    This is a question I would like to know also, ive read there better, amd have them saved on my watch list on eBay so when I do my brake upgrade they will be gping on
  1. Lowering / bush/links replacement.
    By Lordish in forum Handling & Braking
    Last Post: 6th December 2012, 15:53
  2. Rear control arm bush replacement
    By Jock-W in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2012, 14:23
  3. ARB Bush replacement
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2009, 10:00
  4. ARB Bush Replacement Tip
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2009, 07:34
