Thread: Strange problem with head unit (cd30)
    Jul 2011
    gloucestershire
    Trim : Sri
    Engine : 2.0 turbo
    Mileage : 103000
    Default Strange problem with head unit (cd30)
    This morning I have found a problem with my head unit and display. When the radio is on it doesn't show the radio station it just stays on the bc screen and also when I take the keys out the display goes black but the radio stays on. Also the steering wheel controls don't work??? Worked fine until last night when it was cold weather.
    Thanks for your help
    Mike
    Jul 2011
    gloucestershire
    Trim : Sri
    Engine : 2.0 turbo
    Mileage : 103000
    Anyone got any ideas??
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Mine done that once. Pulled the head unit out to kill the power to it, for 10 minutes. Had no issues with mine since
    Jul 2011
    gloucestershire
    Trim : Sri
    Engine : 2.0 turbo
    Mileage : 103000
    Would it be the same just to disconnect the battery? I have never taken a head unit out is it easy?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    If you nip to your local Halfords or car audio place they might do it for a fiver. There may/may not be 4 small torx screws in the holes on the faceplate. Unscrew them and you'll need a pair of double din radio keys. Screws out, push them down the sides to release the clips and it'll pull the radio out when you remove them. Can't see why removing the battery wouldn't do it too though.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by mikey2704 View Post
    Exactly the same mate
    Jul 2011
    gloucestershire
    Trim : Sri
    Engine : 2.0 turbo
    Mileage : 103000
    Thank you both for your help I will try that in the morning and see if it works.
    Thank you again.
  1. CD30 Head Unit Not Working
    By CGSRI in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2009, 08:43
  2. can you run an amp on standard CD30 head unit?
    By MCD in forum Electrical & ICE (including SatNav)
    Last Post: 8th March 2009, 21:23
  3. CD30 Head Unit
    By The Doc in forum Parts for sale
    Last Post: 10th April 2006, 21:42
