Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
Thread: anyone fitted an interior ???
  1. #11
    Wirral / ellesmere port
    13 Post(s)
    Vehicle : Astra j sports tourer
    Trim : elite
    Engine : 1.6 cdti
    Year : 2015
    the little tweeler speakers clip into the triangle door mirror trim and you shud have 3 white little clips on it,just
    push the trim down behind the door card and then locate the white clips into the holes then press securely
    the back upright seats,if you pull 1 of them forward a bit from the locking in position then push it towards the middle
    and it shud come away out of the bottom end outer bracket and then pull it out of the centre bracket and bingo its off.
    the bottom bench,if you get hold of the front centre part of the seat on each side theres a metal bracket that is pushed into
    a white securing clip,if you just tug it up and it shud then come away
  2. #12
    Regular Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    ill give that one a try now
  3. #13
    Dec 2011
    liverpool
    6 Post(s)
    okay so i have the back seats out now need the side bits how do them come out and also the bottom bench ???
  4. #14
    13 Post(s)
    Trim : elite
    Engine : 1.6 cdti
    Year : 2015
    bottom bench comes out as on my previous post
    the side bolsters pull out from the bracket,just get hold of the top and tug it towards you then
    un hook it from the bottom
  5. #15
    Dec 2011
    liverpool
    6 Post(s)
    the bench aint moving as someone has tried to take it out before and ripped the metal bit out the foam
    same with the sides bolsters pulled and pulled an they aint budging the white clips are holding tight so i take it i will need new ones of them to ?
  6. #16
    Dec 2011
    liverpool
    6 Post(s)
    i ahve now managed to snap the white clips when pulling the bottom bench lost my temper abit with it hahaha and the bolster are next on the hit list if they dont watch themselves
  7. #17
    Regular Member bluevec's Avatar
    widnes
    Have you done the front seats, make sure you disconnect the battery and air bag wiring otherwise you will have a warning light.
    They are easy to remove mate.
  8. #18
    Dec 2011
    liverpool
    6 Post(s)
    no mate doing them the weekend but thanks for the info mate greatly appreciated
  9. #19
    widnes
    You will need tx45 to remove the bolts, 1 for the seat belt and 2 on the rail. Then the seat will pull out tilt forward and pull out.
    Much easier than the messing around with door cards.
    Rear door cards are a pain if you have manual winders as there is a C clip with is a pain to get off.
  10. #20
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    the rear seat base clips will nearly always break,the rar bolsers just need a firm tug,look at your new ones and see the clip and how it fits i managed to change my seats in about an hour no probs part frm the base clips breaking,also when fitting front seats make sure you dont scrach the sill plastic trim when geting them into the car,and have a look at the how to hthreardoor c clip try a strip of cloth behin the winder and move back anD forth the cli should snag in the cloth and pull out easily m8
  1. Fitted the leather interior
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2012, 21:26
  2. New interior fitted
    By husky in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2011, 09:45
  3. Leather Interior fitted.
    By badback in forum Styling
    Last Post: 28th July 2009, 20:38
  4. Leather Interior Fitted
    By Robbie69 in forum Styling
    Last Post: 17th December 2008, 01:40
  5. fitted leather interior
    By mitch in forum Quick Photo Album
    Last Post: 27th October 2008, 09:34
