Thread: 206cc oil warning, help please???
    Regular Member sheepish's Avatar
    Yorkshire
    Default 206cc oil warning, help please???
    Hi all,
    I’ve just borrowed the inlaws 2004 (>06/04) 1.6 206cc for a few days while my car is off the road. Now, this car had some problems, it was leaking oil from the oil filter housing and it had been badly over filled with oil. I’ve changed the oil filter and ‘O’ ring and dropped the oil level to where it should be and that’s now ok, no more leak.
    However, when I turn on the ignition it’s flashing usual service distance/warning, but it then still shows the oil over filled warning… I think? It has the row of little squares/zero’s with the oil symbol, but both ‘min’ and ‘max’ are also lit?
    Are there any Pug experts out there that can advise please?
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    As long as all boxes are filled and not dashes it will be fine, also switch the ignition off press and hold the button on the instrument cluster switch the ignition on and it should count from 10-0 then the service light is reset
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    You should always go by the dipstick level and no by the dash gauge
    Dec 2011
    Seaham
    Sounds right to me, the squares are showing the level is up to the max.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    All boxes full means its ok
    But never trust it always use dipstick
    Yorkshire
    Ahhh... that makes sense... many thanks guys!!!
  1. Sat Nav == Warning .
    By HITFACTORY1403 in forum Comedy & Humour
    Last Post: 24th December 2012, 20:46
  2. ******warning*****
    By peter-gsi in forum General Chat
    Last Post: 15th December 2010, 18:23
  3. Warning...................
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2009, 18:20
  4. *** Warning To All Men ***
    By thegoldenbullet in forum General Chat
    Last Post: 17th August 2007, 20:15
  5. Warning!!!!!!!
    By Drinky in forum Comedy & Humour
    Last Post: 26th February 2006, 11:39
