Results 1 to 10 of 13
Thread: Debadging help please
    liverpool
    Default Debadging help please
    Debadging my motor. Removed badges over indicators fine. Letters/numbers on boot chrome again removed without issue. However the griffin badge on boot putting up stubborn resistance. Had heat it up with hair dryer which removed badge but not adhesive. Any tips? Help appreciated.
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    try a little tar remover mate then some rubbing compound that should take it off
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    A rubber sanding block will shift it, then polish off the rubber marks...
    Regular Member Lordish's Avatar
    Feb 2012
    Luton
    I used heat gun to get the Griffin off. Then my nails with the heat gun. I used petrol to get the rest off with some good rubbing. Petrol didn't do any harm on the paintwork. Then t-cut and polish around 3-4 times to get rid of the faint outline. Done my whole car in about 1 hour and a half inc. sides.
    Oct 2012
    coventry
    I used lighter fluid works a treat and a bit of elbow grease lol
    New Member Maff's Avatar
    Aug 2012
    Newport
    elbow grease should do just fine the cold weather atm probably isnt helping tho
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    brillow pad
    Vehicle : .
    Trim : .
    Engine : .
    Year : .
    i used brasso on the GSI when the de-badge left a halo effect - worked a treat
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Quote Originally Posted by neverlandandy View Post
    brillow pad
    you really shouldn't jest bud you would be horrified if he actually thought you meant that and he did damage to his paint
    liverpool
    Cheers thanks for replies. Will probably get some tar remover and start with that. Don't worry, will only try brillow pad if wall paper scraper don't work. Thanks again.
  1. Debadging
    By affirmation in forum Styling
    Last Post: 30th October 2009, 19:35
  2. debadging
    By paul.sessions in forum Photoshop section
    Last Post: 3rd September 2009, 17:36
  3. Debadging
    By saintdean in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2009, 22:23
  4. Debadging my vec
    By veccyjim in forum Styling
    Last Post: 21st May 2009, 22:05
  5. Debadging
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2009, 20:16
