Likes Likes:  7
Results 1 to 10 of 15
Thread: Rear Interior Lighting - LED 501
    Nov 2012
    Inverclyde
    Default Rear Interior Lighting - LED 501
    Just tried to change the rear interior lights with LED. Managed to change the map reading lights and they all work fine however the rear ones aren't. I have checked the polarity and still nothing, and the bulbs are definitely working.
    Anyone had this issue before?
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Yes, do the pins on your LEDs run over both sides? So 2 contacts each side?
    If so you need to cut of or tape 1 each side, the aposing ones and its be fine...
  3. Likes Matty2Fatty liked this post
  4. #3
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by leemarksmith View Post
    This is exactly what fixed mine. Was doing my head in trying to work it out until I asked on here. Looked at them and thought to myself, oh yeah.
    Sorted it and they work fine now.
  5. Likes Matty2Fatty liked this post
  6. #4
    Nov 2012
    Inverclyde
    Superb, will get that done
  7. #5
    Nov 2016
    Sofia
    Vehicle : Vectra C Estate
    Trim : Life
    Hello.
    I've read the above comments but i'm not sure if that's the solution to the problem I have.
    So I installed and wired rear interior lights. It runs normally with normal bulbs, bur when I change them with LEDs both front and rear light are not working when you open the door or try to switch them on. Any advice?
    Thank you in advance... Martin
  8. #6
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    188 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    It's the problem listed above, cover opposite sides of the connector as described cos they are wired in a way that causes a short
    Teapot Tuned 245/300
    https://www.vectra-c.com/forum/calendar.php
  9. Likes Matty2Fatty liked this post
  10. #7
    Nov 2016
    Sofia
    Trim : Life
    Hey thanks for the info.
    After I posted my comment I went down to the car and did this and .. voila!! it worked.....
    Soo happy now hehe
    Best regards... Martin
  11. #8
    Nov 2016
    Sofia
    Trim : Life
    Hey, everything is working perfect, but I noticed that all LEDs are glowing even when they are off. It's a very weak glow and hard to notice when it's not completely dark, but they do this all the time, even when the car is locked. It happens on both my cars, Vectra and Astra.
    Also when I lock both cars, the LED's that are in the headlights and registration plates keep flashing for a few minutes. Then they stop flashing for a few hours and start flashing again for a few minutes. The headlights are not flashing at the same time, but changing...left-right-left-right...etc...
    Is this normal?
    Thank you.. Martin
  12. #9
    Regular Member bigdov's Avatar
    Oct 2016
    Fife
    5 Post(s)
    Trim : Design V6
    Engine : z28net(l)
    All that's normal, the dim glow is just residual current in the circuit, and the flashing is the canbus check system doing it's thing, which oddly enough I've only seen the vectras do, my mk5 astra vxr which is also canbus doesn't do the whole flashing lights thing, still does the fault glow of the courtesy lights tho
    Sent from my HTC One_M8 using Tapatalk
  13. #10
    Nov 2016
    Sofia
    Trim : Life
    Thank you for the asnwer
    My father also has Astra G and the LEDs in headlights keep flashing the same way as in the Vectra and has glow in the interior lights
    Quote Originally Posted by bigdov View Post
  1. interior lighting
    By farley2708 in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2011, 00:23
  2. Alternative Rear Interior Lighting
    By dlm71 in forum Styling
    Last Post: 7th March 2010, 19:20
  3. Interior Lighting
    By lizard in forum Styling
    Last Post: 16th February 2010, 23:36
  4. Done my rear interior lighting
    Last Post: 19th May 2007, 16:01
  5. Rear interior lighting?
    Last Post: 15th May 2007, 15:31
rear interior leds vectra c
rear interior led lights vectra
