Thread: P0104 Mass or Volume Air Flow Circuit Intermittent
    Regular Member andrew_lumb's Avatar
    Nov 2012
    Huddersfield
    Vehicle : Vectra C2
    Mileage : 61000
    Default P0104 Mass or Volume Air Flow Circuit Intermittent
    Hi,
    Just pulled the subject fault code from my ECU as the light came on this morning. Do we know what the typical cause is for this? (Z19DTH Engine)
    Not sure if it is coincidental, I cleaned the intake manifold boost pressure sensor at the weekend, with carb cleaner. Have I likely destroyed the sensor, or do I posibly have another fault?
    Thoughts appreciated
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Check for any intake leaks.
    Nov 2012
    Huddersfield
    Vehicle : Vectra C2
    Mileage : 61000
    Quote Originally Posted by Critch View Post
    I did replace the air filter and temporarily removed the mass flow meter + pipe to do this. Will revisit this tomorrow, see if I missed anything.
    Engine : 1.9 CDTi
    Did you do it with the ignition on?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Double check it clear code am see how you get on
    Nov 2012
    Huddersfield
    Vehicle : Vectra C2
    Mileage : 61000
    Sensor was cleaned with ignition off. Pretty sure I only saw the light after starting and running the car today.
    I have cleared code now, will see if it comes back tomorrow. If so will check sensor is re-fitted correctly, intake pipes are good, then look at replacing sensor if necessary.
  1. Mass or volume air flow circuit
    By don1966 in forum Engine & Drivetrain
    Last Post: 16th November 2012, 22:22
vectra c forum fuse for mass flow
mass or volume air flow a vectra c
P0104 vauxhall
p0104 vectra 1.9 cdti
p0104 1.9 cdti
