Thread: Need advice please help
    Regular Member Rudy's Avatar
    Jul 2012
    Hampshire
    Vehicle : Vectra sri
    Engine : 2.2 direct
    Year : 54
    Mileage : 48000
    Default Need advice please help
    Hi I need any advice that can be given I am wanting out some new breaks on my 2.2 sri direct (discs & pads ) however I don't know if I should go standard or go for some drilled and groves all round got told that drilled and groves are pointless for my car but thought I would try get advice from the veccy experts thanks Rudy
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Why would it be pointless to improve the efficiency of your brakes? Who told you it would be pointless. Do they drive a corsa with a big bore exhaust. Or perhaps a car tuned to death engine wise and no change to suspension/ brakes either way they clearly don't know.
    If you drive fairly refined then it probably wouldn't warrant the extra spend of uprated parts. But your choice mate. Fitting them with a decent compound pad will make braking a lot better
    Jul 2012
    Hampshire
    Engine : 2.2 direct
    Year : 54
    Mileage : 48000
    Well I wanted a set of decent breaks cause I am a bit of a heavy breaker and I made some phone calls to see how much it would cost and I was told that their is no need for anything other then padgid breaks cause my car dont have enough horse power and better breaks would make no difference
    11 Post(s)
    Quote Originally Posted by Rudy View Post
    padgid breaks
    Eh?
    Jul 2012
    Hampshire
    Engine : 2.2 direct
    Year : 54
    Mileage : 48000
    Pagid lol sorry
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Ok, taking improving your driving out of the equation, there are going to be 3 main elements to consider: BRAKE pads... BRAKE discs.... tyres.
    You can have the world's most powerful BRAKES bit if you have lousy traction from rubbish tyres then you'll still have problems. So look to putting decent rubber on your wheels and don't be tempted to run whatever you have down to slicks.
    Pads and discs are combined as soft pads and abrasive discs are about as much use as hard pads and cheap rubbish discs... you need a well balanced combination that are suited to each other and suitable for the application, which in this case is not what would generally be termed a 'high performance' car.
    Straight off there is nothing wrong with the OEM Vx pad & disc kit. The brake setup would be designed to safely stop the vehicle at it's max design weight (plus a safety margin on top) at the maximum speed of the vehicle.
    If you decide you want to fit harder pads, just be aware they may well shorten the life of the standard discs and likewise, if you fit drilled or drilled and grooved discs they may well get through standard pads faster.
    Another option you may wish to consider would be uprating your standard brakes to those of a more powerful Vectra model - the 314mm option will very happily stop a 3.2 V6 from silly mph, so just think the effect they'd have on your 2.2
    Jul 2012
    Hampshire
    Engine : 2.2 direct
    Year : 54
    Mileage : 48000
    Oh ok then thanks that explains a lot
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by Handyandy-UK View Post
    I'd second that. I upgraded my 1.9CDTI to 314's from the standard 285's, with stock discs and pads are they are much better. Even upgrading to 302's would make a substantial difference.
    Jul 2012
    Hampshire
    Engine : 2.2 direct
    Year : 54
    Mileage : 48000
    Can you tell me what I would need to change the disc then I assume calipers but what else would be needed ?
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    front callipers and carriers, discs and pads a direct replacement upgrade, i have a 2,2 direct sri running the 314mm brake upgrade.
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
