Thread: outside temperature display's "F" on the display after battery change
    Regular Member Philhammond2004's Avatar
    Feb 2011
    stafford
    Default outside temperature display's "F" on the display after battery change
    I had to change my battery as it was faulty, I bought the correct battery from halfords. disconnected n reconnected correctly, take the negative off then possitive n reconnecting possitive then negative.
    Everything works fine just like before apart from the outside temperature reading F... I've looked into my handbook and says F means FAULT. Does anyone know what could/ would be the problem? and possible ways of fixing it?
    Any help/ advice would be very greatful
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Try disconnecting the sensor and reconnecting it.
    Feb 2011
    stafford
    Quote Originally Posted by Das View Post
    cheer wheres it located?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Pop the bonnet, look down, its right in the middle of the rear of the front bumper.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    As you have a facelift you will have to remove the front bumper to get to it
    Feb 2011
    stafford
    is it something i can unscrew with my fingers or do i need 2use tool(S) for it? cheers again
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    An "F" you say... I think it's the car saying "****, it's cold out here!"..
    On a Facelift you can just about reach it from under the passenger side of the car lying on the floor... I've often forgotten to put it back before refitting the bumper.... it is possible, it just unclips from the lower grille.
    Matt
  1. Anyone know what a "SAFEGUARD" warning in info display means?
    By andy d in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2016, 21:00
  2. Centre display says "program" Help?
    By mickydoos in forum Electrical & ICE (including SatNav)
    Last Post: 14th October 2009, 14:25
  3. Centre display says "Program" Help?
    Last Post: 9th October 2009, 18:46
  4. Caravan battery "boiling"
    By DaveG in forum The 'Off Topic' room
    Last Post: 22nd April 2009, 08:51
  5. "BRAKE LIGHT" Message in display...
    By Westy SRI in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2008, 23:35
vectra c changing temp display
