Thread: heating... :(
    Regular Member jay14's Avatar
    Feb 2012
    DURHAM
    confused heating... :(
    hi guys, seen bags and bags of threads on heating issues. im not sure whats going on with mine, the only way i can get the fans to work is by pressing the button for the front windscreen demist. no 4 was the only one working for a while but now non of the fan numbers work, also i only have luke warm air blowing though.. its warm enough to demist the windows etc but not enough ata ll to heat the car for my wife and kids to keeo warm... can anybody reccomend a solution or a garage that im not going to get ripped off? i understand it could possibly be the resistor/fuses or relays etc? but im not sure what else and would rather pay someone who knows what they are doing to fix it.
    if any of you guys are up for the challenge i dont mind paying the price, would be handy to know a decent mechanic..
    if you guys have any advice at all or places to go please advise me... i have read loads of people having the same issue..
    Dec 2011
    Seaham
    Think you need to check the fuses, relays and resistor for the blower motor. There is also a motor that opens and shuts the water valve, this can sometimes loose a tooth, there are a few threads about it on the forum.
    For the actual amount of heat, does the car reach full operating temperature? If not then you need to change the engine thermostat.
    I could give you a hand at diagnosing the problems at the weekend?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Where u at? I solved my heating issue.
    1- ur fan resistor packed in. I have new set,
    2- heater matrix need unblocking and cleaning out which solved my heating issue
    3, heater control dials might have some issue if its not blowing to ur choice of air direction means either heater dials or air directive servo which is hardest of all to sort as its up top of air box by steering wheel! (i have a working set if u need it)
    4- bleed the system at full temp setting (put heater dial all way to hot, run fan 1, temp at 85-86ish) then bleed it out to check for air lock to be released.
    If temp gauge dont stay around 85-90 then thermostat housing or thermostat itself need replacing.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Ohh, u live nearby! If u pop over when u're available, i can help u out
    Feb 2012
    DURHAM
    hi man, soo sorry for the delay in reply. i have had a few family issues over the last couple of months and havent had anytime for the car as been using the wifes for work etc. if i could borrow you expertise that would be greatly appreciated. if you could send me your address i will happily travel to you if you could show me what the hell is going on. lol... just want the car running properly again..
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by jay14 View Post
    Me? Lol so we know who u talking to bud :-)
    Feb 2012
    DURHAM
    Yeah man you lol... I just need some serious help as I say.. Wanting to invest a few £££ into the car to get it running properly again.. Just if you have any spare time would appreciate the knowledge
  1. how is your heating ?
    By Tam80 in forum Bodywork & Interior
    Last Post: 28th November 2010, 20:42
  2. No Heating
    By bigmac in forum The 'Off Topic' room
    Last Post: 16th November 2010, 01:08
  3. Over heating???
    By lukesignum in forum Engine & Drivetrain
    Last Post: 16th June 2010, 17:44
  4. Heating temperature control not working - Full heating permanently
    By jratcliffe3 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 23:46
  5. heating
    By dar in forum South Wales (RO - Vacant)
    Last Post: 30th December 2009, 19:36
